qboronyrican Posted May 10, 2007 Report Share Posted May 10, 2007 i found out through much serching and taking my shee apart that i have the set up toomey recomends for thier t5 pipes and wanted to know if thier right or has anyone found them to be off at all?????? the only thing different is that i removed my airbox lid....willl this make it need adjustment????? toomey says: The Toomey Racing T5 Pipes Toomey Racing Silencers Stock carbs Boyesen Reeds on Boyesen RAD-Valves Standard cylinders Needle on the 4th groove ......i think mine is on 3rd #280 Main jet Float setting = 21mm Airscrew at approx. 1.5 turns out from full in. (Effective range .5 to 2.5) Standard pilot jet (#25) Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted May 10, 2007 Report Share Posted May 10, 2007 T-5's are great all around pipes. for the most part they are the number one pipe for a rider that isnt looking for drag or dune. they have great power throughout the whole powerband. Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted May 10, 2007 Author Report Share Posted May 10, 2007 ok........ but that wasnt the Q. i was asking about thier jetting recomendations......thanks anyway though....sorry if i wasnt to clear on that Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted May 10, 2007 Report Share Posted May 10, 2007 (edited) no a 280 sounds small... when i ran fatties with my lid off on stock carbs i ran 320's .... also the pilot was 27.5 air screw 1.5 to 2 turns... needle 4th clip... for the float i want to say they are only 18 or 19...not 21... but im not possitive on that... edit: oh and thats for sea level to about 1000 Edited May 10, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted May 11, 2007 Report Share Posted May 11, 2007 You can't NOT go wrong with Toomeys, all ya gotta do is strap em' on and go i don't think there is to much adjustments to do after installing them. For what i understand. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 11, 2007 Report Share Posted May 11, 2007 You guys are missing his point... If you run an airbox, with a lot of vents or the lid off, and run the Dynojet/Toomey needle, you are fine with those suggestions. Main could be a 270 to 290, depending on temps and elevation as well. The Toomey/Dynojet needle they sell in their "not so perfect" jet kit is longer with more taper, and it has 6 grooves instead of the stock 5. 4th clip down on this aftermarket needle is the Std. position. If you have stockers, leave it in the middle. Put 280's in...and do a proper plug chop. Air screw will be between 1 to 2 turns out, 25 pilot is just fine if you're running an air box setup. If you remove the airbox all together, bump the mains up to 330s or 340s, 27.5 pilot. This is all taking into consideration you're at or near sea level (less than 1000 feet) and you ride in 60 to 80 degree temps. Hope this helps.... Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted May 13, 2007 Report Share Posted May 13, 2007 i run vf3's t5's , k&n in box with lid off, i run a 300 main, 280 was definatly lean with the lid off, this is at 750-1000ft above sea level Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted May 14, 2007 Author Report Share Posted May 14, 2007 thanks dajogejr for getting my point.......and thanks to all for the help.....so i guess im good with what i have and on the 3rd notch untill i find a place to get the shee wot to do a plug chop Quote Link to comment Share on other sites More sharing options...
TWILES Posted May 14, 2007 Report Share Posted May 14, 2007 I used to Toomey kit in mine with his 2into1 airfilter and stock carbs with stock cylinders and mine did fine. I never really got into it that deep or tried to refine it but it ran good most of the time and really good around 70 degrees and low humidity. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 15, 2007 Report Share Posted May 15, 2007 Do you have toomey needles in the carbs? Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted May 15, 2007 Author Report Share Posted May 15, 2007 i guess so ...the needle has 6 notches......how else can you tell Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2007 Report Share Posted May 15, 2007 Toomey and Dynojet is the same needle. Vito's makes one too...but it's red. Both Toomey's and Vitos have the same or similar profile, and they both have 6 notches... The Toomeys even come with a washer for finer tuning, but I never used one of these washer...there's such a slight difference between notches on a needle, I can't see that level of fine tuning needed... Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted May 17, 2007 Author Report Share Posted May 17, 2007 (edited) ok so then yes i have the toomey/dynojet cause i do have the washer ....in the not being used position but it is there. the only difference between mine and what toomey recomendes is that mine is on the 3rd notch and they say 4th Edited May 17, 2007 by qboronyrican Quote Link to comment Share on other sites More sharing options...
