cexualcensations Posted May 8, 2007 Report Share Posted May 8, 2007 I just put my mx motor together and was wondering if my engine compression sounded right. .020 over,17cc domes with 4mm stroker longrod at sealevel came up to 205 psi per cylinder. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 8, 2007 Report Share Posted May 8, 2007 Yep...sounds about right. That's a shit load of compression....hope you had the crank welded up good, and you checked your squish. Goes without saying you'll need 110 octane all the way for that bike... Quote Link to comment Share on other sites More sharing options...
BansheeKid15 Posted May 8, 2007 Report Share Posted May 8, 2007 wow, that is a ton of compression. i agree with dajogejr with the 110 all the way Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted May 8, 2007 Report Share Posted May 8, 2007 I just put my mx motor together and was wondering if my engine compression sounded right. .020 over,17cc domes with 4mm stroker longrod at sealevel came up to 205 psi per cylinder. 205!! holy shhhhh Quote Link to comment Share on other sites More sharing options...
5150banshee Posted May 8, 2007 Report Share Posted May 8, 2007 205 sounds right your gonna be runing 110?? sounds like they did a good job on the motor. Quote Link to comment Share on other sites More sharing options...
blowit Posted May 9, 2007 Report Share Posted May 9, 2007 205 sounds right your gonna be runing 110?? sounds like they did a good job on the motor. 205 sounds even a bit low for an MX motor. We generally make around 250psi static with our MX porting. Makes me wonder how it is ported. Yeah you are in race fuel territory to be safe. The bike should last a long time with those compression numbers. have fun. Brandon Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted May 9, 2007 Report Share Posted May 9, 2007 205 sounds even a bit low for an MX motor. We generally make around 250psi static with our MX porting. Makes me wonder how it is ported. Yeah you are in race fuel territory to be safe. The bike should last a long time with those compression numbers. have fun. Brandon 250PSI?Holy shit how do you kick over any of those bikes then?You have steel boots Quote Link to comment Share on other sites More sharing options...
