Clutch Adjustment Secrets
My friend just put a new Barnett Clutch on his Blaster
got rid of the cushion rings has everything lined up like the Clymers says
But can not get it into second
the Clymers really doesn't go into clutch adj. all that much
Any info would be real helpful
You're asking a Blaster question on a Banshee site....
Not trying to be a smart ass....but, it is what it is.
Try planetblaster or projectblaster.com...
in the banshee world, you have to line up the arms from the clutch actuator arm to the pointer on the case...not sure if it's the same on a blaster...
Then...you have to make sure the shifter is adjusted properly...again, not sure if it's the same on a blaster....
I am not real sure you even have a clutch problem there. Sounds more like a tranny problem or a clutch disengagement problem. If you have grooves worn in the basket or inner drive hub, it will cause poor shifting because the clutch wants to stay engaged. Let me know what your are dealing with.
There are no" secrets" to clutch adjusting. It is a very simple contraption but if you don't get enough disengagement when clutching, shifting will be tough.
Brandon
There is an arrow on the case of the blaster screw in the clutch adjustment screw all the the way take up the slack with your fingers in the clutch arm, and make sure it lines up with the arrow. if not adjust the screw in the center of the pressure plate. Also one friction plate on the blaster is a different size, make sure it is in the right place. There is no adjustment on the clutch pedal on a blaster
Edited by notatallhappy
