what would cool my 'shee better
what cools the shee engine better a NOSS head or a billit impeller
5 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well, I've had the NOSS head for a couple of months now, and I've seen a very big difference with it!!
I can almost touch the head for a bit without getting burned right on the spot... I did that a couple of times with the stock head and it smelled like roasted pig after that :lol:
Add to that the impeller, an inline cooler & some water-wetter and you'd be able to go roostin' on the sun and 'shee wouldn't overheat :wink:
i put a toomey rad on ah its expensive but at the dune a friend with a shee and i were dragging hills and running in the bottoms where there wasnt a bunch of air. my bike was always 15 20 deg cooler than his all he has is a cool head and a in line cooler.
my thoughts
I agree with wesw, the only real way to cool, is to increase your cooling capacity, i.e. Radiator, double the capacity. That is assuming your jetting is correct, if you are lean, you will run hot and nothing will help it except fixing the jetting.
