jbooker82 Posted May 3, 2007 Report Share Posted May 3, 2007 I am getting ready to put together my engine. I will be running wiseco blaster pistons with a 4mill hot rods long rod crank. The pistons didnt come with wirst pin berrings and I was wondering wich ones I need. Ones for a Blaster or ones for a Banshee? I would think that they would be the same ones as you guys running 68mm blaster pistons in a cub with a hot rods 4 mill long rod crank. Thanks for you help josh. Quote Link to comment Share on other sites More sharing options...
woodwardspecialties Posted May 3, 2007 Report Share Posted May 3, 2007 I am getting ready to put together my engine. I will be running wiseco blaster pistons with a 4mill hot rods long rod crank. The pistons didnt come with wirst pin berrings and I was wondering wich ones I need. Ones for a Blaster or ones for a Banshee? I would think that they would be the same ones as you guys running 68mm blaster pistons in a cub with a hot rods 4 mill long rod crank. Thanks for you help josh. the banshee and blaster use the same wrist pin bearings... Part #11-2385 on my website. you have to order them sepratly... as they do not come with the pistons. ost good ships would tell you that when you order the pistons. Quote Link to comment Share on other sites More sharing options...
