jbooker82 Posted May 3, 2007 Report Share Posted May 3, 2007 I am getting ready to put together my engine. 400cc's (Maybe mid 60's for horespower :shrug: Not really sure. Could be more just being concervative) Patriot Racing Drag Ported cylinders. 66mm Bore 4mill Crank Keihin PWK33's with Boss Intake Toomey T5's (I know not the most Ideal pipes for the porting) Cool Head with Race Fuel Domes from patriot racing Timing set at +6 deg V Force reeds K&N Pods Direct Drive Lockup I was thinking about selling my sand stars to a friend and getting some skat track haulers or exteems. I wouldnt have the foggiest Idea on how many paddles to run. I would like to have a 20" tire on 10"rims, but I could probably live with 21"tire on a 10" rim. I dont really like the look of 22" in tires or 8" in rims. I dont really plan on drag racing other than just with friends. So pretty much my two tire sizes I was looking at was 20" or 21" tire on 10" rims. So how many paddles should I get if I change? Regular Haulers or Extreem Haulers? Or should I just keep the Sand Stars? I really apprecat any of the advice I can get from you guys. josh Quote Link to comment Share on other sites More sharing options...
okbeast Posted May 3, 2007 Report Share Posted May 3, 2007 Since you're not too worried about drag racing, a 10 paddle in 20" would probably work good. What size swinger are you going to run? Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 3, 2007 Report Share Posted May 3, 2007 I am getting ready to put together my engine. 400cc's (Maybe mid 60's for horespower :shrug: Not really sure. Could be more just being concervative) Patriot Racing Drag Ported cylinders. 66mm Bore 4mill Crank Keihin PWK33's with Boss Intake Toomey T5's (I know not the most Ideal pipes for the porting) Cool Head with Race Fuel Domes from patriot racing Timing set at +6 deg V Force reeds K&N Pods Direct Drive Lockup I was thinking about selling my sand stars to a friend and getting some skat track haulers or exteems. I wouldnt have the foggiest Idea on how many paddles to run. I would like to have a 20" tire on 10"rims, but I could probably live with 21"tire on a 10" rim. I dont really like the look of 22" in tires or 8" in rims. I dont really plan on drag racing other than just with friends. So pretty much my two tire sizes I was looking at was 20" or 21" tire on 10" rims. So how many paddles should I get if I change? Regular Haulers or Extreem Haulers? Or should I just keep the Sand Stars? I really apprecat any of the advice I can get from you guys. josh My cousin has a patriot 4mill that Dan did, he runs 12 paddle 22x11x8 super lights. Its pretty damn fast. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted May 3, 2007 Report Share Posted May 3, 2007 id say a 21x10x8 10 paddle hauler for dune/drag....should keep your wheel spin up but still have the paddle to handle the motor...... Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted May 3, 2007 Report Share Posted May 3, 2007 it all depends on how long your swinger is Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 3, 2007 Report Share Posted May 3, 2007 Even with T5 pipes...I would be disappointed in Patriot if they only mustered up 60HP...I'd bet they're quite a bit more than that, probably high 70's to low 80s...IMO. I know it's only your estimate...but, you'll be surprised. You probably shouldn't have gotten a drag port if you don't plan on drag racing all that much. A True drag port only has top end, kinda like a cub. No bottom, very little or no mid....which doesn't make for a great duning motor. That being said, if you're not gonna drag race, just keep your sand stars...or get some 10 paddle haulers. I don't see override anywhere in your sig...pulling that clutch in at high revs is gonna be tough with the weights slamming your clutch locked!! Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 3, 2007 Author Report Share Posted May 3, 2007 You probably shouldn't have gotten a drag port if you don't plan on drag racing all that much.A True drag port only has top end, kinda like a cub. No bottom, very little or no mid....which doesn't make for a great duning motor. Your probably right on that one. That is kind of what I am afraid of now that I am getting the engine back to gether. No override yet ethire. I think I might try running around on the sand stars for a wile see how it goes. If the cylinders are to agressive for me then I will probably end up getting rid of them. thanks for your help. I really apprecate it. josh Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 3, 2007 Report Share Posted May 3, 2007 No problem, Josh... Not trying to be a jerk, just trying to keep it real. Don't get me wrong, it'll be a fun bike...but, might be a little harder to keep on the pipe depending on how drastic that drag port is... Good luck!! Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 4, 2007 Author Report Share Posted May 4, 2007 No problem, Josh...Not trying to be a jerk, just trying to keep it real. Don't get me wrong, it'll be a fun bike...but, might be a little harder to keep on the pipe depending on how drastic that drag port is... Good luck!! That is cool I understand. I will just have to try it out and see if I like it. Quote Link to comment Share on other sites More sharing options...
