DGFUNNY70 Posted April 26, 2007 Report Share Posted April 26, 2007 Have any of you used the cascade stuffers on your v-force 3 reeds or just running them like you got them. Quote Link to comment Share on other sites More sharing options...
FireHead Posted April 26, 2007 Report Share Posted April 26, 2007 Have any of you used the cascade stuffers on your v-force 3 reeds or just running them like you got them. I believe the Cascade stuffers are only for carbs that are 38mm or larger. Correct me if I am wrong. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 26, 2007 Report Share Posted April 26, 2007 I got them last year for my VF3's to match my boss intakes. If your intakes have the round style opening I wouldn't use the cascade stuffers and keep with the factory stuffers. If you have the square style intakes then it would surely beat trying to port them yourself to match the stuffer to the intake. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted April 26, 2007 Report Share Posted April 26, 2007 I believe the Cascade stuffers are only for carbs that are 38mm or larger. Correct me if I am wrong. no the stuffers can be used on all sizes, they just replace the vforce stuffers that create a choke point going into the motor. they are nothing more then a flat peice of aluminum tha fits the groove in the reed cage Quote Link to comment Share on other sites More sharing options...
chugger Posted April 26, 2007 Report Share Posted April 26, 2007 I use them have had them almost a month now and now problems not sure how much more power it gave me but for the price every little bit helps. Plus i will need them when i finish the 10mil. Quote Link to comment Share on other sites More sharing options...
cam2 Posted April 27, 2007 Report Share Posted April 27, 2007 (edited) i've been running the cascade stuffers with trinity intakes and VF 3 reeds for about 5 months without any issues. also, if you do use the stuffers that come with the VF 3's you should open the holes up. they are small so i took a dremel and sand paper and opened them up quite a bit before i ran the cascades. Edited April 27, 2007 by cam2 Quote Link to comment Share on other sites More sharing options...
FireHead Posted April 27, 2007 Report Share Posted April 27, 2007 no the stuffers can be used on all sizes, they just replace the vforce stuffers that create a choke point going into the motor.they are nothing more then a flat peice of aluminum tha fits the groove in the reed cage Ok, I guess I didn't remember what Cascade was selling. I made my own stuffers for my VF3's. Quote Link to comment Share on other sites More sharing options...
