Foot Peg Bolt Size?
FireHead
umm, i dont know for sure but i wanna guess...i say
M12 1.5 pitch
That is about what I can remember is that the bolts are something like an M12, but I can remember for sure. I think there are also two different lengths of bolts used on the foot pegs.
I am still hoping someone actually knows the diameter, pitch, and length for sure. :confused:
in the manual it says M10x1.25 but I thought it was M12, might as well buy one of each, i cant be for sure since I'm not looking at my bike, but it is def a 1.25 pitch.
There are very few bolts that arent 1.25 pitch on our bikes
You guys are killing me here. What manual do you have that tells you the bolt size? None of manuals mentioned it. The metric bolt lenght given in inches made me giggle though. Thanks.
if you have a manual it should be listed in the specs. I have the downloaded version and it was in there. I guarantee it is a 1.25 pitch because I had to get one longer than stock for my nerf bars to bolt up.
If you have the downloaded version of the manual it is on pg 47 of 278
Are talking about a Clymer or a Factory Yamaha manual?
www.alloyboltz.com sells some really cool polished foot peg bolts for the banshee for only 20 bolts.. i got them and they look snazzy :thumbsup:
http://www.alloyboltz.com/catalog/product_...roducts_id=1109
I haven't really heard anything good about the alloyboltz kits that were sold after the owner died. I have seen a come pictures of some bolts from one of the Alloyboltz kits and they were ungraded decorative fasteners. I wouldn't reccomend them to anyone, even if I didn't like the person.
He's right. M10 X 1.25
From my research and measurement I found the following:
*M10x1.25 - 50mm is the bolt size that will work in all four foot pegs holes assuming atleast a 2mm thick washer is used.
*I have a shockingly small supply of metric fasteners. None of which, were M10x1.25.
*The Fastenerguy bolt kit tens to use M10x1.5 fasteners for holes that are 10mm in diameter and where a nut is involved (nut is also supplied with the kit. I assume the reason for doing this is that M10x.1.5 is a much more common fastener size and therefore a bit less expensive (there is nothing wrong with doing that by the way. I also assume that this reason is also the reason foot peg bolts do not come in his kits.
*I forgot that I had reinforced the foot peg area on my red bike and in doing so I installed M10x1.5 threaded bosses which I made on a lathe.
Pending me having some difficulty after I obtain the proper fasteners, I am satisfied with the solution I put together with the help of several HQ members. As always, you guys are awesome! :thanks:
