floydfan_90 Posted April 17, 2007 Report Share Posted April 17, 2007 Ok so I need some help! I finally got my a arms in and I need too know if I can use one of the stock Quote Link to comment Share on other sites More sharing options...
floydfan_90 Posted April 17, 2007 Author Report Share Posted April 17, 2007 can i just cut off the back tab and use the front one is it in the corect place? Quote Link to comment Share on other sites More sharing options...
endofitall9 Posted April 17, 2007 Report Share Posted April 17, 2007 There is Plenty of info on here about removing the rear tab...Let me go ahead and enlighten you though...yes you do just remove the rear tab of the J-arm mount and keep the front tab on, that is what is generally done you'll need to grind and cut all the excess off...No there is ot other difference in the geometry so everything should be fine unless your frame is "tweaked" keep in mind that not all frames are "exact" so the A-arm conversion you have may need to be fooled with o fit in your frame as the frame it was mocked on may not be exactly as yours....... :beer: Josh Quote Link to comment Share on other sites More sharing options...
woodro77 Posted April 17, 2007 Report Share Posted April 17, 2007 the a arm frame are different , they have a extra support bar where the back of the a arm bolts to . you would have to add one to your j arm frame . if you need pics let me know. the easiest way is to just buy a a arm frame and swap everything over , you can get a arm frame for a couple hundred bucks and then sell your j arm frame on ebay and recoupe some money back . there is a weld in kit to convert a j arm to a a arm , but im not sure who sells them . i think a guy on here used to sell them , maybe some one remembers his name . i have a straight a arm frame if you need one . Quote Link to comment Share on other sites More sharing options...
cat Posted April 18, 2007 Report Share Posted April 18, 2007 could u post pics of the welded frame? Quote Link to comment Share on other sites More sharing options...
floydfan_90 Posted April 20, 2007 Author Report Share Posted April 20, 2007 There is Plenty of info on here about removing the rear tab...Let me go ahead and enlighten you though...yes you do just remove the rear tab of the J-arm mount and keep the front tab on, that is what is generally done you'll need to grind and cut all the excess off...No there is ot other difference in the geometry so everything should be fine unless your frame is "tweaked" keep in mind that not all frames are "exact" so the A-arm conversion you have may need to be fooled with o fit in your frame as the frame it was mocked on may not be exactly as yours....... :beer: Josh i didn Quote Link to comment Share on other sites More sharing options...
banshee 4 fun Posted April 27, 2007 Report Share Posted April 27, 2007 yes just cut off the tab make sure you have clearance on the backside of the new tube you put in for the steering stem to clear Quote Link to comment Share on other sites More sharing options...
