Arizonaduner Posted April 9, 2007 Report Share Posted April 9, 2007 I saw some stock Banshee front rims for sale on Ebay the other day that had a flat plug (Looked like steel?) in place of the Schrader valvestem. It said in the description that you could use the rim with the offset +2 (Valvestem on the inside). Anyone know what kind of plug they used and how they aired the tire up? I'd really like to have a wider stance up front and still utilize the stock rims. They're pretty durable compared to most aftermarket rims, not to mention they're already paid for. Steve Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) well if you take the tire off your stock rims and take the vavle stem out then put it back in the wrong was so the valve part is on the inside of the rim. all this is used for is to plug the hole. then you drill a hole on the other side of the rim and install a valve stem in the right way. so umm this alowes you to flip your rims around to gain more offset on the front without your vavle stem hitting the brake rotor. i hope you can understand that. another thing you can do is go to your local tire shop and see if they have super short stubby vavle stems that might be easyer because then you could just replace your stock one with a stubby and you wouldnt have to worry about anything once you flip your rims on and if you fell confident you can take the valve caps off your stock valve stems and it will just barly clear your brake rotor when your rims are fliped but its alittle to close for comfort for me. anyway to sum it all up try anf find some stubby valve stems then flip your rims and you will gain width or do the mod i tryed explaining above. i drew a pic lol hope this helps. oh yeah the pic os of the mod this guy is refering to Edited April 9, 2007 by yamaha04 Quote Link to comment Share on other sites More sharing options...
Handyman Posted April 9, 2007 Report Share Posted April 9, 2007 cascadeinnovations.net has this..all it is is a different type if valve stem but it's flat. It takes a special tool to air up the tire. Read the discription on the site and it will explain everything. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 9, 2007 Report Share Posted April 9, 2007 It is just called a flush mount valve stem. Any tire shop should have them, or should be able to get them for you. josh Quote Link to comment Share on other sites More sharing options...
