J-WELDO Posted April 9, 2007 Report Share Posted April 9, 2007 (edited) Hey guys need some help, just got the cub together spent two hours breaking in ,let warm up and cool down and so on.Then took it to the dunes ran great out of gate never rode it hard went to climb a dune and lost my right cylinder,so I replaced plug still nothing then I noticed that the fuel line came apart and soaked my filter so I removed the filter and started still nothing, but the carb was spitting allot of fuel back out of the air intake side of carb any help please I very worried, everything is new got about 4,000 invested in rebuild new tranny 4mil crank,barrnet clutch,36mm carbs,spacers,v3 reeds,cpi inframe,pro des. coolhead 18cc domes on 111 octane,+6 timing,793mo68 wiseco blaster pistons,lighten flywheel.Any suggestions or anybody with simular problems? I forgot to mention it will fire at high rpms but is hard to take off got no power. :ermm: Edited April 9, 2007 by J-WELDO Quote Link to comment Share on other sites More sharing options...
wesw Posted April 9, 2007 Report Share Posted April 9, 2007 if your getting gas to back wave thru the carb you most likely have reed problems. will it even idle?? Quote Link to comment Share on other sites More sharing options...
r/atvshee Posted April 9, 2007 Report Share Posted April 9, 2007 bad floats could be an issue too Quote Link to comment Share on other sites More sharing options...
J-WELDO Posted April 9, 2007 Author Report Share Posted April 9, 2007 if your getting gas to back wave thru the carb you most likely have reed problems. will it even idle?? Yes on one cylinder but when I rev it up the other cylinder starts firing but when I let it come back to idle the other cylinder dead again Quote Link to comment Share on other sites More sharing options...
wesw Posted April 9, 2007 Report Share Posted April 9, 2007 are your carbs synced at all. all i know if your getting gas to shoot back thru the carb you have issues. rn brads bike was that way at the dunes wouldnt idle ran like ass. i think he is getting new reeds. i had some vf2 go bad wouldnt idle it would idle high the fall on its ass. motor ran like barely on one jug. i would start that. pull the reeds off and you should see any light. the pedals should be closed completely. Quote Link to comment Share on other sites More sharing options...
J-WELDO Posted April 9, 2007 Author Report Share Posted April 9, 2007 Yes on one cylinder but when I rev it up the other cylinder starts firing but when I let it come back to idle the other cylinder dead again You guys think a better set of carbs I have mikunni t36 flatslide with power valves but power valves are closed for now till I break it in fully I was thinking maybey some lectrons Quote Link to comment Share on other sites More sharing options...
J-WELDO Posted April 9, 2007 Author Report Share Posted April 9, 2007 I will check reeds tomorrow I hope this it it would be a easy fix thanks Quote Link to comment Share on other sites More sharing options...
bada450r Posted April 9, 2007 Report Share Posted April 9, 2007 bad floats could be an issue too what he saud ^^^^^^^^^^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
syclone Posted April 9, 2007 Report Share Posted April 9, 2007 what he saud ^^^^^^^^^^^^^^^^^ it's likly your main did a 180 and is now pointing out of carb,i,ve seen this happen quit a few times. take your filter off and make sure it is still pointing into cylinder. Quote Link to comment Share on other sites More sharing options...
J-WELDO Posted April 9, 2007 Author Report Share Posted April 9, 2007 it's likly your main did a 180 and is now pointing out of carb,i,ve seen this happen quit a few times. take your filter off and make sure it is still pointing into cylinder. Yes main is fine so thats not it but thanks anyway Quote Link to comment Share on other sites More sharing options...
chugger Posted April 9, 2007 Report Share Posted April 9, 2007 Yes main is fine so thats not it but thanks anyway my vote would be the reeds Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted April 9, 2007 Report Share Posted April 9, 2007 I'm thinking reeds... floats could make it run like crap too... Hope you figure it out man! Quote Link to comment Share on other sites More sharing options...
dante Posted April 9, 2007 Report Share Posted April 9, 2007 Check your tail pipe for bananas! :biggrin: I here the Kawasaki guys are lurking. LOL Quote Link to comment Share on other sites More sharing options...
ALTVATER Posted April 9, 2007 Report Share Posted April 9, 2007 my 421 did that this weekend also i just took my carbs apart and cleaned the hell out of the floats. i think my oil in my tank settled b/c my floats were covered in oil. just an idea i don't know if it will help u and u might have already went through ur carbs. but after i did that it fired up and ran great. Quote Link to comment Share on other sites More sharing options...
J-WELDO Posted April 10, 2007 Author Report Share Posted April 10, 2007 my 421 did that this weekend also i just took my carbs apart and cleaned the hell out of the floats. i think my oil in my tank settled b/c my floats were covered in oil. just an idea i don't know if it will help u and u might have already went through ur carbs. but after i did that it fired up and ran great. It was the reed petals.Thanks allot guys rock on shee HQ!! :biggrin: Quote Link to comment Share on other sites More sharing options...
