need some help!
yep drain your tranny fluid, coolant, you have to take off the R foot peg, your kickstarter, the breather tube comming out of the top of the clutch cover by the water pump spigot(SP) take out the nine cover bolts dont strip them they are a pain to get out!!! your coolant hose through the cases will be very snug so you may have to wiggle it a bit to get her off. try not to pull your kicker out with it, since your new it could be a pain for ya! then you have complete access to the right side of your engine.
