fox_forma Posted April 6, 2007 Report Share Posted April 6, 2007 One of my engine mount bolts completely snapped off. It was the one that connects to the frame so I drilled it out slowly, then put an extractor bit in it and apparently the extractor bit was shit and snapped off inside the bolt now. Is there anyway to drill this out again? None of the bits I have will cut through the extractor and keep going. I dont know where to go from here, I have never had this type of problem before extracting a broken bolt. Oh and the bolt isnt sticking out at all Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted April 6, 2007 Report Share Posted April 6, 2007 One of my engine mount bolts completely snapped off. It was the one that connects to the frame so I drilled it out slowly, then put an extractor bit in it and apparently the extractor bit was shit and snapped off inside the bolt now. Is there anyway to drill this out again? None of the bits I have will cut through the extractor and keep going. I dont know where to go from here, I have never had this type of problem before extracting a broken bolt. Oh and the bolt isnt sticking out at all Do you have access to a welder? If not how about at least a propane torch? Quote Link to comment Share on other sites More sharing options...
fox_forma Posted April 6, 2007 Author Report Share Posted April 6, 2007 no welder, but have a propane torch, why? Quote Link to comment Share on other sites More sharing options...
Moddoo Posted April 6, 2007 Report Share Posted April 6, 2007 If you can get a carbide drill bit (hard to find) , that will work. Another trick is to get a carbide tipped concrete bit (easy to find) and sharpen it on a grinder. That will work well also. The trick is to start it centered and keep it centered. Quote Link to comment Share on other sites More sharing options...
fox_forma Posted April 6, 2007 Author Report Share Posted April 6, 2007 What about them carbide bits used with dremels? Quote Link to comment Share on other sites More sharing options...
BANSHEEMANIAC Posted April 6, 2007 Report Share Posted April 6, 2007 get a colbalt bit. they are cheaper and easier to find. i done the same thing, and the colbalt bit cut right thru it. Quote Link to comment Share on other sites More sharing options...
64xracer Posted April 6, 2007 Report Share Posted April 6, 2007 You can get a good hard center punch and chip away at the extractor. The best bet is to tig weld a nut onto the broken extractor and unscrew it. Put a little heat on the outside of the boss and use WD-40 or bee's wax after you take the heat off. It should come out. If you can not get it or don't think you can, find a machine shop in your area and they will get it out. EDM is the best way, but that is not a home fix it yourself deal. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted April 6, 2007 Report Share Posted April 6, 2007 get a colbalt bit. they are cheaper and easier to find. i done the same thing, and the colbalt bit cut right thru it. word :thumbsup: use a batterry drill with a clutch at a slow speed. clutch drill will stop toque from breakin bits. try using cutting oil too. Quote Link to comment Share on other sites More sharing options...
racer Posted April 6, 2007 Report Share Posted April 6, 2007 If you can get a carbide drill bit (hard to find) , that will work.Another trick is to get a carbide tipped concrete bit (easy to find) and sharpen it on a grinder. 1, a carbide drill will be very expensive too. 2, dont touch your grinder with any carbide surface. it will eat your wheel faster than it will take an edge. Quote Link to comment Share on other sites More sharing options...
racer Posted April 6, 2007 Report Share Posted April 6, 2007 if you can find one use a left hand drill and spin your drill motor in reverse. that way one of two things happens: A) you cut through the material, or the bit catches and spins the bolt out. Quote Link to comment Share on other sites More sharing options...
Moddoo Posted April 6, 2007 Report Share Posted April 6, 2007 1, a carbide drill will be very expensive too. 2, dont touch your grinder with any carbide surface. it will eat your wheel faster than it will take an edge. I offered my advice because I have done it before and it works well. A carbide tipped concrete bit costs less than $5 and can easily be shapened on a standard grinding wheel in under a minute without doing damage to the wheel. Quote Link to comment Share on other sites More sharing options...
fox_forma Posted April 6, 2007 Author Report Share Posted April 6, 2007 get a colbalt bit. they are cheaper and easier to find. i done the same thing, and the colbalt bit cut right thru it. went through 2 of them so far and they broke, would not grab for shit. I used a carbide bit I have for my dremel and so far I am picking away at the extractor slowly. Its taking a while but seems to be cutting away at it better than anything else. Couldnt find a carbide tipped concrete bit yet though Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 6, 2007 Report Share Posted April 6, 2007 get a colbalt bit. they are cheaper and easier to find. i done the same thing, and the colbalt bit cut right thru it. Carbide is very hard. The only thing that is going to cut through carbide is a carbide drill bit. If you used a colbalt drill bit then your extractor wasnt made of carbide. Quote Link to comment Share on other sites More sharing options...
racer Posted April 6, 2007 Report Share Posted April 6, 2007 A carbide tipped concrete bit costs less than $5 and can easily be shapened on a standard grinding wheel in under a minute without doing damage to the wheel. Ya, my bad, Im looking at too many things. Im a machinist; and the pure carbides we use will eat any wheel, other than diamond. I dont think the concrete bits use that high of quality probably. So that probably is feasible, or you have some sweet ass wheels. Its funny cause we were sharpening tools today and the grinder ate up every M-42 or HSS tool we had, no questions asked. But we saved the single carbide center as the last job. It ate a 4inch wheel to ~3.5inches before it put a 60* point on the tool. haha Quote Link to comment Share on other sites More sharing options...
David Keith Posted April 6, 2007 Report Share Posted April 6, 2007 What about them carbide bits used with dremels? If you've tried these other tips & the broken extracter & bolt are still in, a dremel hand grinder with a carbide grinding tip can be used to grind away all of it. Why don't you try this? Quote Link to comment Share on other sites More sharing options...
