Snowmann Posted March 31, 2007 Report Posted March 31, 2007 Complete '96 banshee part out... the quad spun a rod bearing and the crank is junk as well as the left side piston... the cylinders look great not scored actually just need a ball hone run through them... case bearing areas are still in good shape just the pesky needle bearing on the left bank seized... old plastic is junk no bumper and no grab bar... heres the preliminary list - nothing has been taken apart yet except for the motor... Ill pull parts as they are requested All prices as SHIPPED - however a few of the bigger items - wheels/tires, the cases, the axle, etc will be on a qoute basis as they are gonna be a mess to ship... **AS SHIPPED PRICES** -Engine Cylinders $170 Head $25 Keihen 28mm carbs/with 1month old intake boots $100 Airbox with K&N filter and airbox adaptor $25 Race Cut Wiring harness - includes pull tether kill switch, CDI and Coil mounted to a relocation bracket under the tank, TORS removal and master power removal - runs the high beams at all time $55 Coil with NGK ends... less than 2hrs on coil $70 CDI $25 Radiator $40 (Will include new hoses with less than 2hrs) ***Bottom End $150 Inlcludes EVERYTHING from the cylinders down - From the Stator to the Clutch and a 12t sprocket. Ill even throw in the crank if you want it... SHIPPING IS QUOTED ON THIS ITEM!!!!!! Stock Silencers and pipes $55 Gas Tank $45 -Suspension YFZ 450 A-arms $125 (ready to install on a bansee for a wider front end) YFZ 450 tie rods with new ends $100 Honda 450R Front Shocks $200 Works Rear Shock $175 Stock Hubs painted red $35/pair Stock Swing arm $60 Stock Steering Stem with Renthal MX bars $50 ***DuraBlue Axle - up to +3 on rear will include rear carrier and chainwheel $150 SHIPPING IS QUOTED ON THIS ITEM!!!!!! Calipers and Brake Lines $35 - front / $25 - rear Rear Master cylinder and lever $35 ***Black Wrinkle Coat Frame - reinforced and crack inspected and repaired. I only rode this around in the parking lot in the winter... frame is MINT hasnt seen trail riding $300 SHIPPING IS QUOTED ON THIS ITEM!!!!!! DG Aluminum nerfs $45 ****Quoted Shipping on Wheels**** Stock Front Wheels with tires $60 Stock Rear Wheels with tires $60 Aftermarket polished wheels with Turf Tamers (unsure of manufacturer of wheel) $60 Any other misc parts off a banshee that someone needs let me know! I do have pictures of some of the bigger ticket items... or the items that people might want to see... request pics and ill email em out to ya! I will be out of town until monday nite... but will start replying and tearing down the bike ASAP... Thank! Quote
06BaNsHeE Posted March 31, 2007 Report Posted March 31, 2007 I will take the carbs right now.Anything wrong with them? Quote
grpark20 Posted April 1, 2007 Report Posted April 1, 2007 Complete '96 banshee part out... the quad spun a rod bearing and the crank is junk as well as the left side piston...the cylinders look great not scored actually just need a ball hone run through them... case bearing areas are still in good shape just the pesky needle bearing on the left bank seized... old plastic is junk no bumper and no grab bar... heres the preliminary list - nothing has been taken apart yet except for the motor... Ill pull parts as they are requested All prices as SHIPPED - however a few of the bigger items - wheels/tires, the cases, the axle, etc will be on a qoute basis as they are gonna be a mess to ship... **AS SHIPPED PRICES** -Engine Cylinders $170 Head $25 Keihen 28mm carbs/with 1month old intake boots $100 Airbox with K&N filter and airbox adaptor $25 Race Cut Wiring harness - includes pull tether kill switch, CDI and Coil mounted to a relocation bracket under the tank, TORS removal and master power removal - runs the high beams at all time $55 Coil with NGK ends... less than 2hrs on coil $70 CDI $25 Radiator $40 (Will include new hoses with less than 2hrs) ***Bottom End $150 Inlcludes EVERYTHING from the cylinders down - From the Stator to the Clutch and a 12t sprocket. Ill even throw in the crank if you want it... SHIPPING IS QUOTED ON THIS ITEM!!!!!! Stock Silencers and pipes $55 Gas Tank $45 -Suspension YFZ 450 A-arms $125 (ready to install on a bansee for a wider front end) YFZ 450 tie rods with new ends $100 Honda 450R Front Shocks $200 Works Rear Shock $175 Stock Hubs painted red $35/pair Stock Swing arm $60 Stock Steering Stem with Renthal MX bars $50 ***DuraBlue Axle - up to +3 on rear will include rear carrier and chainwheel $150 SHIPPING IS QUOTED ON THIS ITEM!!!!!! Calipers and Brake Lines $35 - front / $25 - rear Rear Master cylinder and lever $35 ***Black Wrinkle Coat Frame - reinforced and crack inspected and repaired. I only rode this around in the parking lot in the winter... frame is MINT hasnt seen trail riding $300 SHIPPING IS QUOTED ON THIS ITEM!!!!!! DG Aluminum nerfs $45 ****Quoted Shipping on Wheels**** Stock Front Wheels with tires $60 Stock Rear Wheels with tires $60 Aftermarket polished wheels with Turf Tamers (unsure of manufacturer of wheel) $60 Any other misc parts off a banshee that someone needs let me know! I do have pictures of some of the bigger ticket items... or the items that people might want to see... request pics and ill email em out to ya! I will be out of town until monday nite... but will start replying and tearing down the bike ASAP... Thank! What bore size are the cylinders? Quote
s-540 Posted April 2, 2007 Report Posted April 2, 2007 (edited) iam interested in the bottom end. how is the tranny?and how much shipped to phx,az 85085? do you also have a picture? Edited April 2, 2007 by s-540 Quote
darkside Posted April 2, 2007 Report Posted April 2, 2007 iam interested in the bottom end. how is the tranny?and how much shipped to phx,az 85085?do you also have a picture? how much for the frame shipped to 91001? Quote
laker31 Posted April 2, 2007 Report Posted April 2, 2007 Will you sell the bars without steering stem??? Quote
Ryda85 Posted April 2, 2007 Report Posted April 2, 2007 the front end is already modified for a banshee? ie bolt on? any pics? Quote
Snowmann Posted April 2, 2007 Author Report Posted April 2, 2007 Guys - this is going to be too hard and time consuming for me to do via the forums... so heres what im gonna do... Im going to list these on ebay - if any BansheeHQ member wins the item - tell me you're a Banshee HQ member in the payment form and Ill ship them for free as long as its not the cases - axle - or wheels... Thanks and sorry I couldnt do this - I had 54 PM's when I logged on last nite and about 32 were 'first dibs' on the carbs lol... im listing parts now - heres the link to my current auctions eh it takes a bit for the 'view sellers other items' thing to register that im selling several items... heres a link to the shocks... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...p;rd=1&rd=1 Quote
LiftdT4R Posted April 4, 2007 Report Posted April 4, 2007 Payment sent on the carbs. Thanks man! :beer: Quote
Snowmann Posted April 6, 2007 Author Report Posted April 6, 2007 bummp cylinders, shocks, a-arms, and axle are on ebay right now folks http://motors.search.ebay.com/_W0QQsassZsnowmann33 Quote
jaybanshee Posted April 6, 2007 Report Posted April 6, 2007 How about the Stock Hubs painted red $35/pair... Do you still have them? Is that the front and the rear and is the red paint still good??? Quote
