Complete Banshee Part out... YZF front end, keihen 28mm, powdercoat frame etc...
Complete '96 banshee part out... the quad spun a rod bearing and the crank is junk as well as the left side piston...
the cylinders look great not scored actually just need a ball hone run through them... case bearing areas are still in good shape
just the pesky needle bearing on the left bank seized... old plastic is junk no bumper and no grab bar...
heres the preliminary list - nothing has been taken apart yet except for the motor... Ill pull parts as they are requested
All prices as SHIPPED - however a few of the bigger items - wheels/tires, the cases, the axle, etc will be on a qoute basis as they are gonna be a mess to ship...
**AS SHIPPED PRICES**
-Engine
Cylinders $170
Head $25
Keihen 28mm carbs/with 1month old intake boots $100
Airbox with K&N filter and airbox adaptor $25
Race Cut Wiring harness - includes pull tether kill switch, CDI and Coil mounted to a relocation bracket under the tank, TORS removal and master power removal - runs the high beams at all time $55
Coil with NGK ends... less than 2hrs on coil $70
CDI $25
Radiator $40 (Will include new hoses with less than 2hrs)
***Bottom End $150 Inlcludes EVERYTHING from the cylinders down - From the Stator to the Clutch and a 12t sprocket. Ill even throw in the crank if you want it... SHIPPING IS QUOTED ON THIS ITEM!!!!!!
Stock Silencers and pipes $55
Gas Tank $45
-Suspension
YFZ 450 A-arms $125 (ready to install on a bansee for a wider front end)
YFZ 450 tie rods with new ends $100
Honda 450R Front Shocks $200
Works Rear Shock $175
Stock Hubs painted red $35/pair
Stock Swing arm $60
Stock Steering Stem with Renthal MX bars $50
***DuraBlue Axle - up to +3 on rear will include rear carrier and chainwheel $150 SHIPPING IS QUOTED ON THIS ITEM!!!!!!
Calipers and Brake Lines $35 - front / $25 - rear
Rear Master cylinder and lever $35
***Black Wrinkle Coat Frame - reinforced and crack inspected and repaired. I only rode this around in the parking lot in the winter... frame is MINT hasnt seen trail riding $300 SHIPPING IS QUOTED ON THIS ITEM!!!!!!
DG Aluminum nerfs $45
****Quoted Shipping on Wheels****
Stock Front Wheels with tires $60
Stock Rear Wheels with tires $60
Aftermarket polished wheels with Turf Tamers (unsure of manufacturer of wheel) $60
Any other misc parts off a banshee that someone needs let me know!
I do have pictures of some of the bigger ticket items... or the items that people might want to see... request pics and ill email em out to ya!
I will be out of town until monday nite... but will start replying and tearing down the bike ASAP...
Thank!
-Engine
Cylinders $170
Head $25
CDI $25
Gas Tank $45
-Suspension
Stock Swing arm $60
Thank!
What bore size are the cylinders?
Guys - this is going to be too hard and time consuming for me to do via the forums...
so heres what im gonna do... Im going to list these on ebay - if any BansheeHQ member wins the item - tell me you're a Banshee HQ member in the payment form and Ill ship them for free as long as its not the cases - axle - or wheels...
Thanks and sorry I couldnt do this - I had 54 PM's when I logged on last nite and about 32 were 'first dibs' on the carbs lol...
im listing parts now - heres the link to my current auctions
eh it takes a bit for the 'view sellers other items' thing to register that im selling several items... heres a link to the shocks...
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...p;rd=1&rd=1
