nixon186 Posted March 31, 2007 Report Share Posted March 31, 2007 i recently purchased a 2000 banshee. i have ridden it a few times over the last month with no issues. i just noticed that after giving it some throttle and i let off, it seems to idle about 200-300 rpm too high. it does it for about 10 seconds then it drops down to normal idle. i just lubed the throttle cable and it didn't seem to do anything. i thought it may be an airleak, but wouldn't it idle high constantly and never drop down?i'll spray it down tomorrow night anyway to check for a leak. any other ideas on what it could be? BTW... it does run perfectly. Quote Link to comment Share on other sites More sharing options...
chevrolet banshee Posted March 31, 2007 Report Share Posted March 31, 2007 it has to burn the extra feul Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 31, 2007 Report Share Posted March 31, 2007 I would say an air leak to. A lean condition is causing the hanging idle. Quote Link to comment Share on other sites More sharing options...
CadillacBanshee Posted March 31, 2007 Report Share Posted March 31, 2007 Air leaks definatley cause this. Check around your intake boots for cracks and loose clamps. Quote Link to comment Share on other sites More sharing options...
nixon186 Posted March 31, 2007 Author Report Share Posted March 31, 2007 the guy who had it before me put a boost bottle on it too. i figured it would only be a short time before the stupid thing leaked. i'll check for leaks tonight and if i discover its the boost bottle im just takin it off. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 1, 2007 Report Share Posted April 1, 2007 The boost bottle doesnt leak it causes the rubber boots to crack around where it slips in to the intakes. Ethire way I would ditch the bottle. My Boss intake has a crossover tube machined in to it. I think you can get them for stock to 28mm carbs too. Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted April 5, 2007 Report Share Posted April 5, 2007 (edited) after giving it some throttle and i let off, it seems to idle about 200-300 rpm too high. it does it for about 10 seconds then it drops down to normal idle. Sounds textbook for a lean pilot curcuit. Pilot circuit may be too lean due to improper jet selection or foreign matter clogging the jet. That will cause the motor to display the symptoms you describe. Try adjusting your air screw(s) and see if that makes a change for you or check the pilot jets for gunk or restriction in the orifice. Jay From SanD. BTW: You may want to post this in the exhaust/jetting section to get more coverage.... :thumbsup: Edited April 5, 2007 by jayzx750 Quote Link to comment Share on other sites More sharing options...
