375hp banshees Posted March 30, 2007 Report Share Posted March 30, 2007 my mains say 350, my mods are in my sig... my plug chop said dead on ...350 seams high doesn't it...i'm @ sea level & here is A pic of my current lid w/ K&N & outerwares going to K&N 6" clamp on's Thanks Dave Quote Link to comment Share on other sites More sharing options...
mpbanshee Posted March 30, 2007 Report Share Posted March 30, 2007 If you are dead on now, you will need to go up a size or two with the clamp-ons. However, 350 sounds way big for your mods. I would clean the carbs out really good, and also check for air leaks. Then do another chop with the 350's, and see if anything changes. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 30, 2007 Report Share Posted March 30, 2007 did you do the chop when it was still cool outside? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 30, 2007 Author Report Share Posted March 30, 2007 If you are dead on now, you will need to go up a size or two with the clamp-ons. However, 350 sounds way big for your mods. I would clean the carbs out really good, and also check for air leaks. Then do another chop with the 350's, and see if anything changes. did that last plug chop :thumbsup: my clip is all the way up so I run A little cooler putting w/ my daughter but that shouldn't effect plug chop I couldn't remember what was in there so I got 'em apart now was supprised to see 350 :shrug: Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 30, 2007 Author Report Share Posted March 30, 2007 did you do the chop when it was still cool outside? what day was that :biggrin: no temps were 90 ish... we all did chops at big scrub back in oct. nov. ? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 30, 2007 Author Report Share Posted March 30, 2007 If you are dead on now, you will need to go up a size or two with the clamp-ons. However, 350 sounds way big for your mods. I would clean the carbs out really good, and also check for air leaks. Then do another chop with the 350's, and see if anything changes. what incroments(sp) do they jump in Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 30, 2007 Report Share Posted March 30, 2007 Id leave it and see what happens. Your clip was all the way up,. thats the leanest setting,. so if you filter need more juice,. you could always lower it first. Over 350 is pretty extreme. Youll probley just need to turn in the air screw a half or so and drop your clip a notch or 2. Once it gets hotter out, the motor will run richer too. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 30, 2007 Author Report Share Posted March 30, 2007 Id leave it and see what happens. Your clip was all the way up,. thats the leanest setting,. so if you filter need more juice,. you could always lower it first. Over 350 is pretty extreme. Youll probley just need to turn in the air screw a half or so and drop your clip a notch or 2. Once it gets hotter out, the motor will run richer too. oops... needle all the way up, :biggrin: not the clip Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 30, 2007 Author Report Share Posted March 30, 2007 ????????????????????????????/ Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 30, 2007 Report Share Posted March 30, 2007 www.jetsrus.com have them in increments of 10 from 350-400. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 30, 2007 Report Share Posted March 30, 2007 Why is the needle that rich. In my experience...that main is way rich for your bike, elevation and temps. However, ojcool will back me on this, plugs don't lie.... (Sorry, had to...) :yelrotflmao: If you're putting around on the bike with your daughter, having the needle on the richest setting will foul plugs more than anything.... How does it run with the needle in the middle?? Putting pods on should lean the jetting out. So...I'd take one run with the pods at the same jetting you have now. If it still shows good, something is wrong, or the plug chop is not being done correctly.... If the jetting is spot on now....the plugs should be white as rice when you chop. You should need to go 360 to 380 on them mains.... Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 31, 2007 Author Report Share Posted March 31, 2007 Why is the needle that rich.In my experience...that main is way rich for your bike, elevation and temps. However, ojcool will back me on this, plugs don't lie.... (Sorry, had to...) :yelrotflmao: If you're putting around on the bike with your daughter, having the needle on the richest setting will foul plugs more than anything.... How does it run with the needle in the middle?? Putting pods on should lean the jetting out. So...I'd take one run with the pods at the same jetting you have now. If it still shows good, something is wrong, or the plug chop is not being done correctly.... If the jetting is spot on now....the plugs should be white as rice when you chop. You should need to go 360 to 380 on them mains.... its A little blubbery just b4 the pipe, runs great wot 1-6... did plug chop correctly...haven't fouled A plug yet ...will redo w/ current set up & w/pods tomorrow, wont be able to rejet since nobody has 300+ jets in stock...I still have the last plug will post it for opinions,I thought 350 was way high & was supprised to see them in there...do plugs lie? here it is Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 31, 2007 Report Share Posted March 31, 2007 based on that pic, your mains are spot on. Leave them. Plugs don't lie...but, they also can't tell you if there's something wrong with your motor. If you're sure the carbs are cleaned out and in good working order....it is what it is. Fix the air screws next...they're the easiest... Warm the bike up, turn each screw all the way in, then out .5 turns. Wait 20 seconds. Keep turning it out .25 to .5 turns at a time (waiting 20 seconds between turns) to get the highest idle. Bike has to be warm to set them this way.. Then I'd say play with the needle...but, seeing as how you're gonna lean it out by putting pods on it....leave the needle for now. Good luck!! Quote Link to comment Share on other sites More sharing options...
cam2 Posted March 31, 2007 Report Share Posted March 31, 2007 my mains say 350, my mods are in my sig... my plug chop said dead on ...350 seams high doesn't it...i'm @ sea level & here is A pic of my current lid w/ K&N & outerwares going to K&N 6" clamp on's Thanks Dave dave, didn't you buy the bike used? are you sure the jugs weren't ported? are the jets clearly stamped with a "3" and not with a "2" for the first #? i agree, the plug looks good. i'm not trying to bust your balls but "350" does seem large. before i had my stock jugs ported my setup was damn near the same as yours. except i didn't have v-force reeds, and i ran a dual stage foam filter without the lid instead of the K&N filter with the lid. i know the K&N flows better than the dual stage foam, but i don't think it would be that big of a difference especially since you're running a lid and i was't. if i remember correctly i used "280" mains and stock pilots, i forget the needle position. hopefully you don't have an airleak. if everything checks good and you find that you need larger pilots and you can't get them locally let me know and i'll mail them to you. i have 27.5 pilots if you need them. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 1, 2007 Author Report Share Posted April 1, 2007 dave, didn't you buy the bike used? are you sure the jugs weren't ported? are the jets clearly stamped with a "3" and not with a "2" for the first #? i agree, the plug looks good. i'm not trying to bust your balls but "350" does seem large. before i had my stock jugs ported my setup was damn near the same as yours. except i didn't have v-force reeds, and i ran a dual stage foam filter without the lid instead of the K&N filter with the lid. i know the K&N flows better than the dual stage foam, but i don't think it would be that big of a difference especially since you're running a lid and i was't. if i remember correctly i used "280" mains and stock pilots, i forget the needle position. hopefully you don't have an airleak. if everything checks good and you find that you need larger pilots and you can't get them locally let me know and i'll mail them to you. i have 27.5 pilots if you need them. started to run like crap in 5th & 6th by the end of the day will change plugs tomorrow & see if that is the prob ...didn't have A chance to do filters today either, my daughter wanted to tag along so we putted all day, + at was dusty & didn't want to fill the motor w/ dirt . do have an enteresting thing happen to gary's shee. he let his son ride it & he wasn't sure when to shift (said these 2 strokes just keep reving :: ) when he stopped it was on fire the pipes turned blue at the head & at the stinger so much the rubbers caught on fire :shoothead: :shoothead: :shoothead: Quote Link to comment Share on other sites More sharing options...
