socal909 Posted March 29, 2007 Report Share Posted March 29, 2007 whats up guys im looking to rebuild my bike and adding some more power. i want to add as much as i can with out boreing out "staying at 350". i was thinking pistons and cams! what do you guys think, any help please. mods: drag port cpi inframe mill head to run 91/112 35 pwks carbs k&N pods v force 3 reeds +6 timing thanks again! Quote Link to comment Share on other sites More sharing options...
jmd0346 Posted March 29, 2007 Report Share Posted March 29, 2007 whats up guys im looking to rebuild my bike and adding some more power. i want to add as much as i can with out boreing out "staying at 350". i was thinking pistons and cams! what do you guys think, any help please. mods: drag port cpi inframe mill head to run 91/112 35 pwks carbs k&N pods v force 3 reeds +6 timing thanks again! Cams. Definitely cams. Quote Link to comment Share on other sites More sharing options...
Rustbag Posted March 29, 2007 Report Share Posted March 29, 2007 Cams. Definitely cams. ROTFLMAO Quote Link to comment Share on other sites More sharing options...
JET 99 Posted March 29, 2007 Report Share Posted March 29, 2007 what kinda lift and duration are you thinking bout. i heard that the rocker arms are bitch to adjust in the heads if you go to extreme... :beer: Quote Link to comment Share on other sites More sharing options...
blueboy22 Posted March 29, 2007 Report Share Posted March 29, 2007 .....and your sure you have a banshee right? :yelrotflmao: :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 29, 2007 Report Share Posted March 29, 2007 what kinda lift and duration are you thinking bout.i heard that the rocker arms are bitch to adjust in the heads if you go to extreme... :beer: yea On mine I had to adjust the lash like 3 times. SOB. Quote Link to comment Share on other sites More sharing options...
jmd0346 Posted March 30, 2007 Report Share Posted March 30, 2007 In all seriousness. These may help. Quote Link to comment Share on other sites More sharing options...
socal909 Posted March 30, 2007 Author Report Share Posted March 30, 2007 In all seriousness. These may help. lol what does fit a trackter? Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 30, 2007 Report Share Posted March 30, 2007 no for real, put a crane cams roller in there with some power bands and a boost bottle and you betterr put a weelie bar on it!! :happy: Quote Link to comment Share on other sites More sharing options...
socal909 Posted March 30, 2007 Author Report Share Posted March 30, 2007 for the setup that i have what size pistons should i go with? Quote Link to comment Share on other sites More sharing options...
mpbanshee Posted March 30, 2007 Report Share Posted March 30, 2007 for the setup that i have what size pistons should i go with? I'd go with like some 18:1 high compression pistons. Especially if you got some extensive port and flow work done on the heads. Get some heavier valve springs also... Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted March 30, 2007 Report Share Posted March 30, 2007 for the setup that i have what size pistons should i go with? forged ceramic coated ross pistons with chrome moly rings to protect them from all the boost from the bottle. make sure the pistons have the right valve relief so the valves dont hit the pistons, esecially with a high lift cam. Quote Link to comment Share on other sites More sharing options...
jmd0346 Posted March 30, 2007 Report Share Posted March 30, 2007 for the setup that i have what size pistons should i go with? I wouldnt change piston sizes unless you need to. It sounds to me like you need to send the jugs off to a reputable shop and let them handle it. Also, two stroke engines do not have cams. We're laughing at you not with you. Quote Link to comment Share on other sites More sharing options...
mod quad 2 Posted March 30, 2007 Report Share Posted March 30, 2007 maybe a new pink powerband or even the new camo series for wicked power :cool: :geek: Quote Link to comment Share on other sites More sharing options...
chevy7398 Posted March 30, 2007 Report Share Posted March 30, 2007 ya and get a new rev limiter so you can wind her out more, and for the extra couple bucks get a roller cam Quote Link to comment Share on other sites More sharing options...
