FireHead Posted March 27, 2007 Report Share Posted March 27, 2007 i generally use some KY warming gel or some Vaseline if its around. otherwise i just spit at it. :biggrin: You may want to look into Rim Ease that can be purchased via the link below. http://www.pitposse.com/rimeatimolu.html :yelrotflmao: :yelrotflmao: :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted March 27, 2007 Report Share Posted March 27, 2007 What is the courseness rating of the stones you are using on the hone? Do you know what type os stones you have (cemented carbide, aluminum oxide, etc.)? You should be fine with a drill to do the honing. In your case it might be harder to use a mill to do the work IMO. stones are silicon carbide.240 320 400 and 600 grit was going to use the oil i cut with on the mill not the mill to do the work. Quote Link to comment Share on other sites More sharing options...
