onemoretoy Posted March 24, 2007 Report Share Posted March 24, 2007 I'M HAVING A SET OF A ARMS BUILT , ON A 450 WITH SUSPENSION FULLY DROPED ON THE SHOCK FROM PIN TO PIN IT MEASURES 15 1/2 INCHES ON MY BANSHEE IT 14 1/2 . NOW IF YOU MOVED THE LOWER SHOCK MOUNT OUT 1 INCH WOULD THIS FIX THE PROBLM .BY THE WAY THIS IS A J ARM BIKE . GETTING A SET OF CHROMOLY J ARMS /KIT BUILT Quote Link to comment Share on other sites More sharing options...
Ruko Posted March 25, 2007 Report Share Posted March 25, 2007 I had mine built like that from Sanddragon a couple years ago... I think it actually worked out to about 3/4 of an inch out because the a-arm is angled down as well. They work great by the way... don't see why it should be any different for J-arms. If you chick on my sig pic they are a bunch more pics of it there. Quote Link to comment Share on other sites More sharing options...
STREETSWEEPAZ Posted March 30, 2007 Report Share Posted March 30, 2007 wouldnt you need upper & lowers built ???? Im wondering the same thing here .. I jave an 87 & I think im going to fabricate something - Arm & shock relocation brackets or Do the arms up .............. I dont know alot about banshees but I know a good portion about extending control arms on my Lowriders... HA Quote Link to comment Share on other sites More sharing options...
Ruko Posted March 31, 2007 Report Share Posted March 31, 2007 The shocks only mount to the lower a-arms. The upper end mounts to the frame. So if you leave the upper mount as is and move the lower mount out you get a longer eye to eye distance between the two, in order to use the longer shocks from a 450. Although just to make sure I have you're question right... yes you need to get or build both upper and lower a-arms to get the extra length, but you only need to move the mount out on the lower one. Quote Link to comment Share on other sites More sharing options...
onemoretoy Posted April 2, 2007 Author Report Share Posted April 2, 2007 The shocks only mount to the lower a-arms. The upper end mounts to the frame. So if you leave the upper mount as is and move the lower mount out you get a longer eye to eye distance between the two, in order to use the longer shocks from a 450. Although just to make sure I have you're question right... yes you need to get or build both upper and lower a-arms to get the extra length, but you only need to move the mount out on the lower one. thanks for the info and yes this is a set of new chromoly jarms and lower a arms were the shock mount will be moved out , there also going to be +2+1 Quote Link to comment Share on other sites More sharing options...
