06BaNsHeE Posted March 24, 2007 Report Share Posted March 24, 2007 (edited) My bestfriend wants to mix 1 quart of maxima and half of belray.Both 80w?My friend needs tranny oil and I only have half of belray gear saver and he has a quart of maxima.Is it bad to mix them?I WANNA RIDE lol Edited March 24, 2007 by 06BaNsHeE Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted March 24, 2007 Report Share Posted March 24, 2007 Well its not ever real good to mix two different manufacturers oils. It can cause premature heat break down, varnishing, and sludging in an engine. With spending big bucks on a new tranny or clutch in mind, I wouldn't do it. Quote Link to comment Share on other sites More sharing options...
brugal Posted March 25, 2007 Report Share Posted March 25, 2007 I wouldnt. Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted March 25, 2007 Report Share Posted March 25, 2007 well what about lucas heavy duty oil stabilizer? it says it blends with other automotiv lubrcant even ATF, mineral oil and synthetic oil your supposed to put 200ml in with the other oil you use so it would be 1.3 litres of yamalube4 and 200ml of the lucas stuffed Quote Link to comment Share on other sites More sharing options...
ojcool Posted March 25, 2007 Report Share Posted March 25, 2007 No, technically there is no reason you cannot mix oil..... But don't expect to mix conventional oil and synthetic and get the same protection... You won't. Or weights of oil.. But they will all mix. But if you mix a quart of 10/30 and a quart of 10/40 you will affect the viscosity. Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted March 25, 2007 Report Share Posted March 25, 2007 http://www.eliteone.com/images/lucas/stabilizer.jpg Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted March 25, 2007 Author Report Share Posted March 25, 2007 Forget it he went to the stealership and bought tranny oil.Thanks guys Quote Link to comment Share on other sites More sharing options...
