chris1992 Posted March 23, 2007 Report Share Posted March 23, 2007 (edited) ok.. i just noticed today.. (only had it for a few weeks) that my front banshee a-arms are different then most pics ive seen.... everyone elses has 2 normal arm but mine has one normal arm on the bottm and one thick, steel J-shaped tube on the top.. did a search and this is supposed to be rare or something.. whats the deal? the hinges dont look the same either.. and i have a problem with tht.. i was onna upgrade to a +2+1 setup ... DOES THIS MEAN I CANT DO THAT!? Edited March 23, 2007 by chris1992 Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 23, 2007 Report Share Posted March 23, 2007 ok.. i just noticed today.. (only had it for a few weeks) that my front banshee a-arms are different then most pics ive seen.... everyone elses has 2 normal arm but mine has one normal arm on the bottm and one thick, steel J-shaped tube on the top.. did a search and this is supposed to be rare or something.. whats the deal? the hinges dont look the same either.. and i have a problem with tht.. i was onna upgrade to a +2+1 setup ... DOES THIS MEAN I CANT DO THAT!? No, it's not rare so to speak, it just means you have an early bike with J-arms. I think some companies, at least used to, not sure now, made longer j-arms. But as far as buying a standard +2+1 A-arm setup no you can't. You can conver the j-arm from to a-arm mounts, but it takes a substantial amount of work. Unless you feel pretty confident in your fabrication skills I would recommend looking for an A-arm frame bike if you are dead set on widening the front. Quote Link to comment Share on other sites More sharing options...
chris1992 Posted March 23, 2007 Author Report Share Posted March 23, 2007 :: Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted March 23, 2007 Report Share Posted March 23, 2007 They sell extended J-Arms, look around. Aside from that, you can buy an a arm frame for a few hundred, or modify the frame you have. Those are your options. Quote Link to comment Share on other sites More sharing options...
