best setting for std suspension
BeemerGee
My guess for stock would be to max out the preload on the front shocks and for the rear, max out the comp. and go 3/4 loose on the rebound. The rebound is the knob at the base of the shock. I didn't know that till 3 years after I owned my Banshee. Good luck.
Hi Guys what would be the best setting on the standard suspension for jumps? What would be the best/cheaper option for better suspension upgrade for jumps. Thanks
You can have the rear shock revalved and resprung for around $300-350, good basic fronts will run around $450.
