Trick2stroke Posted March 21, 2007 Report Share Posted March 21, 2007 Where's a cheap online place to order bushings for the a arms/shocks? Everywhere I look they only sell bearring kits which are far too expensive right now when I could replace them with bushings. Thanks. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 21, 2007 Report Share Posted March 21, 2007 u mean the nylon bushings? any dealership can get them.. try ebay also... they are prety much universal.. Quote Link to comment Share on other sites More sharing options...
brugal Posted March 21, 2007 Report Share Posted March 21, 2007 Where's a cheap online place to order bushings for the a arms/shocks? Everywhere I look they only sell bearring kits which are far too expensive right now when I could replace them with bushings. Thanks. Ebay Quote Link to comment Share on other sites More sharing options...
FireHead Posted March 21, 2007 Report Share Posted March 21, 2007 RMATV Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted March 21, 2007 Author Report Share Posted March 21, 2007 (edited) RMATV only has bearrings fram what I can see. I'll check ebay. I found the a arm bushings but still no luck with the shock bushings. Edited March 21, 2007 by Trick2stroke Quote Link to comment Share on other sites More sharing options...
Mullet Man Posted March 21, 2007 Report Share Posted March 21, 2007 RMATV only has bearrings fram what I can see. I'll check ebay. I found the a arm bushings but still no luck with the shock bushings. i just happened across the shock bushings the other day, now i cant remember where it was. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted March 21, 2007 Author Report Share Posted March 21, 2007 i just happened across the shock bushings the other day, now i cant remember where it was. :: lol I'm anxious to get all this on. I'll search around some more after class. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted March 21, 2007 Report Share Posted March 21, 2007 but still no luck with the shock bushings. I'm not sure if you can replace them or not, if you can I think it may only be either the top or bottom, I can't remember. Back in the day I tried to do the same and was told I couldn't do it by someone, and I ended up just buying aftermarket shocks. I could be wrong though :shrug: Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted March 21, 2007 Author Report Share Posted March 21, 2007 It's the top and bottom bushings in a set of works duals. Quote Link to comment Share on other sites More sharing options...
FireHead Posted March 21, 2007 Report Share Posted March 21, 2007 RMATV only has bearrings fram what I can see. I'll check ebay. I found the a arm bushings but still no luck with the shock bushings. RMATV interchanges the terms bearing and bushing quote frequently. Beyond that, if it is bearings for a works shock that is needed, especially an older one like the one that is pictured in this thread. You will need to call or email Works directly. :thumbsup: Quote Link to comment Share on other sites More sharing options...
