Engine Ice
Is there a noticable differnece when switching to it
Between Engine Ice and Redline Water Wetter you will see a small increase in cooling efficiency. There are alot of factors involved with effectively cooling a Banshee. No matter what Engine Ice is a high quality coolant. Whether you will acutally be able to see a physical difference on a gauge or otherwise, maybe or maybe not. :thumbsup:
I had a problem with overflowing coolant when riding a very short track with minimal straightaways. I switched to Engine Ice and It doesnt do it anymore.
I was reading 190-205 head temps without it (using infrared thermometer) I am now reading 140-170 head temps But it is about 20 deg f cooler outside now so Its not accurate data. But no more overflows
It wasnt quite overheating with regular coolant in it but it was getting hot enough to spit a little out on the right side pipe every so often. Even in cooler weather.
Id say for $15-$20 go for it you cant go wrong. Its much better than reg coolant. Only slightly better than water wetter and water , but it does have freeze protection unlike water wetter , which does not protect from freezing.
I think you touched upon the main difference between Engine Ice and Water Wetter. If you don't need freeze protection then Water Wetter is just as good of a product. :geek:
whats the mix with this engine ice and water wetter stuff?
would it be good for the trails
Edited by 350BANSHEE350
I was thinking about running engine ice this time around since i dont have any fluid in my bike... My only question is i do have a small amount of regular (preston) coolant in the jugs. Would it be a bad idea to change over to engine ice with that still in the jugs?
Another stupid question :blush: . Where can you buy it? i was at kragen and the yamaha store and looked around quick and didnt see any.\
Thanks
Thanks
i got my water wetter at cycle gear here in so cal,but as stated if you use water wetter,do not use it at 32f or below,cuz it will freeze.also the directions are in the back of the bottle.for me it sures beats paying 17 bucks everytime i drain my fluids.you can get like 4 gal of solution w water wetter. :thumbsup: :thumbsup:
Thanks
Having the coolant in the jugs when you put the engine ice in, is not a problem. :thumbsup:
