Tire pressure?
casper
I need some help on proper tire pressure, I was out at Dumont this weekend and just got beat up by all of the chop. I have been putting 4.5lb in the rear and 4lb in the front, I run Haulers in the rear and sand stars in the front. I have this problem on both my shee and my yfz450, my 450 realy beats me up, anyone know the proper setting for the stock shocks? I am about a buck 50 if that helps.
Thanks :confused:
Thanks :confused:
On rough days I will run up to 10psi in my front tires and get down to around 3psi in the rear. I have found when it is rough and you let more air out of the fronts the more the bike is tossed around. Letting a little air out of the back put more of the paddle profile in the sand, which may not make it smoother but it will get you a little better taction in rutted up conditions. :geek:
Would adjusting the compression on the springs also help?
Adjusting the preload in the springs is purely a ride height and weight distribution technique. All it does is index the spring in relation to the shock body. It does not change the spring rate. :geek:
