woodro77 Posted March 17, 2007 Report Share Posted March 17, 2007 i have a set of cylinders and pistons and trying to tell what size bore they are on , the pistons say , ( 50-520P ), on them and under that it says ( STD ) on them , does this mean standard bore , as in stock bore? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 17, 2007 Report Share Posted March 17, 2007 what kind of piston is it? i know my weisco have the series and the bore in mm... so its like 00-795 006400 or something like that... Quote Link to comment Share on other sites More sharing options...
blowit Posted March 17, 2007 Report Share Posted March 17, 2007 what kind of piston is it? i know my weisco have the series and the bore in mm... so its like 00-795 006400 or something like that... Yes, STD is for standard or stock OEM bore size. For the banshee, that is 64mm unless you have some other pistons in it. For instance, the 66mm Blaster pistons used in the long rod setup. The piston will say STD but the bore is NOT 64mm. Just know what you have and you are all good. Brandon Quote Link to comment Share on other sites More sharing options...
woodro77 Posted March 17, 2007 Author Report Share Posted March 17, 2007 Yes, STD is for standard or stock OEM bore size. For the banshee, that is 64mm unless you have some other pistons in it. For instance, the 66mm Blaster pistons used in the long rod setup. The piston will say STD but the bore is NOT 64mm. Just know what you have and you are all good. Brandon this is a stock motor , i figured it was stock just wanted to make sure , i know they usually say the bore on them i dont know what kind of pistons they are , maybe vito's they dont look like oem's Quote Link to comment Share on other sites More sharing options...
