400rednEX Posted March 15, 2007 Report Share Posted March 15, 2007 i hear about modifying your intakes when you put in v force 3's, but do you have to do anything when you have the trinity single carb and switch to v forces? i have fmf ram valves now and i assume the opinion is it's worth switching to v forces? would spacers between the intake and the reed blocks help with the sharp turn into the reed blocks? Quote Link to comment Share on other sites More sharing options...
man27 Posted March 15, 2007 Report Share Posted March 15, 2007 (edited) I use v force and I just put them in I didn't modify nothing and they perform great and I use spacers but they give me clearance for my carbs thats all I care about my opinion is thats all they do they don't give no horse power or throttle responce. since you have 1 carb setup I wouldn't use the spacers my.02 cents :cool: Edited March 15, 2007 by man27 Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 15, 2007 Report Share Posted March 15, 2007 I use v force and I just put them in I didn't modify nothing and they perform great and I use spacers but they give me clearance for my carbs thats all I care about my opinion is thats all they do they don't give no horse power or throttle responce. since you have 1 carb setup I wouldn't use the spacers my.02 cents :cool: Well I'm willing to bet you'd be in the minority believing that the VF3's don't do a thing. I know on a dual carb setup they far outperform the stock cages. Now, I have heard arguments about whether or not they outdo modded cages with TDR reeds, but they will definitely outdo stock cages. Now, you're already running rad valves so you may not see a signiificant bump by switching to VF3's. Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted March 15, 2007 Report Share Posted March 15, 2007 Well I'm willing to bet you'd be in the minority believing that the VF3's don't do a thing. I know on a dual carb setup they far outperform the stock cages. Now, I have heard arguments about whether or not they outdo modded cages with TDR reeds, but they will definitely outdo stock cages. Now, you're already running rad valves so you may not see a signiificant bump by switching to VF3's. he was refer to the spacers not doing anything Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 15, 2007 Report Share Posted March 15, 2007 he was refer to the spacers not doing anything damn, you're right. I think that is the nyquil telling me it is time to stop posting and time to get my sick butt in bed. I need to be well to ride this weekend anyway. sorry! Quote Link to comment Share on other sites More sharing options...
man27 Posted March 15, 2007 Report Share Posted March 15, 2007 Well I'm willing to bet you'd be in the minority believing that the VF3's don't do a thing. I know on a dual carb setup they far outperform the stock cages. Now, I have heard arguments about whether or not they outdo modded cages with TDR reeds, but they will definitely outdo stock cages. Now, you're already running rad valves so you may not see a signiificant bump by switching to VF3's. I was reffering to his question about the spacers not the reeds, the v vorce are the best reeds you can buy!!! Quote Link to comment Share on other sites More sharing options...
man27 Posted March 15, 2007 Report Share Posted March 15, 2007 damn, you're right. I think that is the nyquil telling me it is time to stop posting and time to get my sick butt in bed. I need to be well to ride this weekend anyway. sorry! No big deal!!! :beer: Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 15, 2007 Report Share Posted March 15, 2007 I was reffering to his question about the spacers not the reeds, the v vorce are the best reeds you can buy!!! I'll agree with that and shut my mouth until I am a little less foggy up top. :beer: Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 15, 2007 Report Share Posted March 15, 2007 i hear about modifying your intakes when you put in v force 3's, but do you have to do anything when you have the trinity single carb and switch to v forces? i have fmf ram valves now and i assume the opinion is it's worth switching to v forces? would spacers between the intake and the reed blocks help with the sharp turn into the reed blocks? The modding you hear about with the stock dual carb setup is that you have to cut a tab off of the intake boots. VForce 3 reeds aslo have a round hole that is desigend to match up to the stock round carb boots. Your trinity intake has a big opean square right? Cascade sells what they call a reed stuffer. That makes the opeaing of the VForce 3 reeds a big square instead of a small round hole. That would be the best mod to improve flow. You can see by the pic how much better it would be for your 2:1 carb. You could also try reed spacers but they are really designed to go between the cylinder and the reed block, not the reed block and carb intake. If you put it inbetween the reed and intake, then the intake doesnt have a smooth flow and they would hurt perfromance more than help. Here a pic and a link. Cascade V Force LINK Quote Link to comment Share on other sites More sharing options...
400rednEX Posted March 15, 2007 Author Report Share Posted March 15, 2007 yes, the single carb intake has big squared ports so it looks like the stuffers would be just the ticket, thanks. hopefully the o rings in the intake will still line up with a flat surface to seal to. has anyone switched from ram valves to v forces and seen a gain? Quote Link to comment Share on other sites More sharing options...
