Swingarm Mount Questions (Aluminum Spacer)
ZillaRider02
OK Guys, I'm heading out to the garage (Yes, it's 5:45am) to start the Banshee assembly. It's been awhile since I removed the -2" swinger from the Shee. Today, it gets a +2". There was an aluminum spacer between the swinger and frame on the old arm. I'm assuming all Banshee's have this? It goes on the chain side or brake side? Thanks guys..........
1: REAR ARM COMP.
33449-001
$330.09
2: BEARING,CYL.#17
(U49)
360506-001
$11.85
3: OIL SEAL,OSO-TYPE
(35-41-8)
358861-001
$5.11
4: COVER,THRUST 1
(U49)
24139-001
$11.86
5: WASHER,PLATE (2VM)
,(5NG1)
1074-001
$5.45
6: BUSH
(U49)
22140-001
$33.62
7: SHAFT,PIVOT
(U49)
22135-001
$39.31
8: WASHER,PLATE
(U49)
347292-001
$4.38
9: NUT,SELF-LOCKING
,(5NG1)
363498-001
$7.75
10: SEAL, GUARD
(U49)
22137-001
$5.77
11: STOPPER,MAIN STAND
(U49)
284392-001
$2.94
12: SUPPORT,CHAIN
(U49)
301119-001
$11.73
13: BOLT, FLANGE
(8X40)
363957-001
$1.21
14: ARM,RELAY
(U49)
14006-001
$328.05
15: BUSH,FORMED
(U49)
349524-001
$4.38
16: OIL SEAL
,(5NG1)
899-001
$2.86
17: COLLAR
(U49)
350573-001
$6.69
18: BOLT
(U49)
343744-001
$6.86
19: NIPPLE,GREASE
(USA)
361145-001
$3.39
20: WASHER,PLATE
(U49)
346935-001
$2.55
21: NUT,SELF-LOCKING
(5PA1)
346476-001
$4.42
22: ROD,CONNECTING 1
(U49)
33450-001
$56.33
23: BUSH,FORMED
(U49)
349523-001
$4.38
24: COVER,THRUST 2
(U49)
293059-001
$7.35
25: COLLAR
(U49)
350572-001
$5.77
27: BOLT
(U49)
343665-001
$4.42
28: WASHER,PLATE
(U49)
347086-001
$3.31
29: WASHER, PLATE
(U49)
347054-001
$2.44
31: BOLT
(U49)
343720-001
$4.66
34: COVER
(U49)
33451-001
$133.14
35: BOLT,FLANGE(8AB)
UR CA 5SCL
363954-001
$0.95
36: GUARD, CHAIN
(U49)
22138-001
$20.39
37: BOLT
(U49)
364496-001
$0.45
38: WASHER, PLATE (6TA)
,(5LY1)
788-001
$0.35
39: NUT,U
,(USA)
4804-001
$0.86
40: WASHER (6TA)
(YMUS)
358100-001
$0.46
41: NUT,U
(5NX1)
4954-001
$2.35
42: COLLAR
(U49)
22139-001
$9.74
