WuddupDoc Posted March 14, 2007 Report Share Posted March 14, 2007 What you perfer to use? Quote Link to comment Share on other sites More sharing options...
CenCalBanshee Posted March 14, 2007 Report Share Posted March 14, 2007 I use the motul, Its always worked fine for me Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 14, 2007 Report Share Posted March 14, 2007 I prefer Tri-Flow. I ride in the sand and most of the other stuff leaves too much residue and draws sand. But, Tri-Flow stick with it better than WD40 or something like those. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 14, 2007 Report Share Posted March 14, 2007 tri-flow is a great product.. only draw back is it drys reletivly fast so you got to keep applying it if your out for a long weeknd.. but like 2003 said it wont collect sand all over your chain like others will... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 15, 2007 Report Share Posted March 15, 2007 Bel Ray Super Clean It doesn't get dirt stuck to it and it doesn't fling off. Quote Link to comment Share on other sites More sharing options...
91banshee Posted March 15, 2007 Report Share Posted March 15, 2007 What you perfer to use? for the past few years ive used Kerosen mixed with diesel fuel , makes the chain super clean and lubed perfect and wont let dirt stick to it , screw chain lube or chain wax , those are dirt magnets , you can see yourself in the chain on my quad and its still quiet and smooth Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted March 15, 2007 Report Share Posted March 15, 2007 Pledge, to get the dust off. Quote Link to comment Share on other sites More sharing options...
pokeatyou2 Posted March 15, 2007 Report Share Posted March 15, 2007 belray super clean Quote Link to comment Share on other sites More sharing options...
dante Posted March 15, 2007 Report Share Posted March 15, 2007 Honda chain lube it dosen't sling off. Quote Link to comment Share on other sites More sharing options...
KlotzBanshee Posted March 15, 2007 Report Share Posted March 15, 2007 Maxima Chain wax works best for me. I've tried many others and the Maxima just seems to work the best. But you have to apply it per the directions or it will collect sand. Never seen or tried the Tri-flow though. IMO any thing you use is going to get dirt on it. Clean the mofo once in a while...its called general maintenance. :wink: Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted March 15, 2007 Report Share Posted March 15, 2007 Ya, everything I use I need to clean it off after a ween=kend and reapply it because it has sand caked on it, which has to be good for it, right Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 16, 2007 Report Share Posted March 16, 2007 Maxima Chain wax works best for me. I've tried many others and the Maxima just seems to work the best. But you have to apply it per the directions or it will collect sand. Never seen or tried the Tri-flow though. IMO any thing you use is going to get dirt on it. Clean the mofo once in a while...its called general maintenance. :wink: Totally agree you have to perform some general maintenance if you expect everything to work right. Otherwise you build on the stigma that "those Banshee guys always have to work on their $h!t..." I will admit that I bought some of the Chain Wax stuff but never ran it in the sand. I applied it, it seemed really tacky so I read on the can and it said it leaves a cosmolene like finish. So, knowing I didn't want anything like cosmolene on my chain I immediately cleaned it and started using Tri-Flow. It's worked great for me for several years now... Quote Link to comment Share on other sites More sharing options...
