bertski077 Posted March 14, 2007 Report Share Posted March 14, 2007 i am 150lbs i ride mostly mx and i have +3 a arms on stock yfz shocks...i was wondering wat i should set my preload, rebound and compression too? right now it seems that the shocks dont want to spring back up as fast as it seems they should? if i lift the bike off the ground and drop it, the a arms stay pretty much as far in as they can get instead of going back to where they were b4 when i sit on it...hopefully it makes sense and someone can help me out. thanks. Ben Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted March 14, 2007 Report Share Posted March 14, 2007 Do you mean the don't uncompress as fast as the compress? If so thats all about your rebound im not even sure if you can adjust rebound on them. If you can soften it up some see how that goes. Seems like your also saying the are soft if so just tighten up that preload some. Honestly its trial and error. Your riding style and preference has a lot to do with it also. Just keep trying stuff till you get it how ya like it. One other small tip when setting preload sit on the bike yourself and have a friend adjust it with your weight on the bike. Quote Link to comment Share on other sites More sharing options...
