thack Posted March 14, 2007 Report Share Posted March 14, 2007 OK I JUST PUT A .030 DECKED HEAD ON .GOING TO PUT A ADJUSTABLE TIMING PLATE ON NEXT WEEK WHEN IT GETS HERE.IVE GOT FATTY PIPES UNI FILTER .BOYSEN REEDS.STOCK BORE AND PORTING.WITH 145 PSI COMPRESION WITH A NOLIGY COIL.JETTING IS SPOT ON EXEPT THE PLUGS READ A LITTLE HOT MY BR8ES PLUGS ELECTRODE SHOWS A COLOR CHANGE CLOSER TO THE WELD INDICATING A HOT PLUG .SHOULD I BUMP THE FUEL UP SOME OR GO TO A BR9ES PLUG .RUNNING 93 OCTANE AT THE MOMENT BUT I CAN CUT IT WITH AV FUEL IF I NEED TO .JETTING IS 270 MAINS WITH DYNOJET NEEDLES(DNO304),CLIP ON THE FOURTH GROVE.1000 FEET ELEVATION. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted March 14, 2007 Report Share Posted March 14, 2007 OK I JUST PUT A .030 DECKED HEAD ON .GOING TO PUT A ADJUSTABLE TIMING PLATE ON NEXT WEEK WHEN IT GETS HERE.IVE GOT FATTY PIPES UNI FILTER .BOYSEN REEDS.STOCK BORE AND PORTING.WITH 145 PSI COMPRESION WITH A NOLIGY COIL.JETTING IS SPOT ON EXEPT THE PLUGS READ A LITTLE HOT MY BR8ES PLUGS ELECTRODE SHOWS A COLOR CHANGE CLOSER TO THE WELD INDICATING A HOT PLUG .SHOULD I BUMP THE FUEL UP SOME OR GO TO A BR9ES PLUG .RUNNING 93 OCTANE AT THE MOMENT BUT I CAN CUT IT WITH AV FUEL IF I NEED TO .JETTING IS 270 MAINS WITH DYNOJET NEEDLES(DNO304),CLIP ON THE FOURTH GROVE.1000 FEET ELEVATION. Color change....which color...you want the weld to be black and turning chocalate brown where the electrode bends and maintaining chocalate color across the tip...tan is lean. Quote Link to comment Share on other sites More sharing options...
thack Posted March 14, 2007 Author Report Share Posted March 14, 2007 (edited) Color change....which color...you want the weld to be black and turning chocalate brown where the electrode bends and maintaining chocalate color across the tip...tan is lean. check out my pics and look under plug pics .lookes like thats close to me .ceramic is dirty thanks to my fat fingers almost dropping it and grabing the ceramic end to catch it Edited March 14, 2007 by thack Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 14, 2007 Report Share Posted March 14, 2007 The jetting looks pretty close to me, maybe a tad rich, but not by much if at all. However, with your compression and timing I wouldn't think it would be necessary to switch to a BR9ES. Quote Link to comment Share on other sites More sharing options...
okbeast Posted March 14, 2007 Report Share Posted March 14, 2007 How exactly are you doing the plug chop? They should look like this: http://www.bansheehq.com/index.php?option=...3&Itemid=28 but yours come out with all of the electrode brown... Quote Link to comment Share on other sites More sharing options...
thack Posted March 14, 2007 Author Report Share Posted March 14, 2007 How exactly are you doing the plug chop? They should look like this: http://www.bansheehq.com/index.php?option=...3&Itemid=28 but yours come out with all of the electrode brown... not all brown my dirty fingers had a little to do with that. i need to do the plug chop they way it was described and check agian . Quote Link to comment Share on other sites More sharing options...
pokeatyou2 Posted March 14, 2007 Report Share Posted March 14, 2007 The jetting looks pretty close to me, maybe a tad rich, but not by much if at all. However, with your compression and timing I wouldn't think it would be necessary to switch to a BR9ES. when is it neceesary to switch to br9es Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted March 15, 2007 Report Share Posted March 15, 2007 when is it neceesary to switch to br9es A lot of people just run the 8's. I prefer running 9's with my compression and timing just to be on the safe side. If your bike is tuned properly it will handle the 9's no problem, I replace my plugs once a season just for grins, but I have yet to foul a plug running 9's. However, if you're bike is rich and it doesn't need the 9's it will foul them. Making the switch is just a further ping or detonation risk reducer. To give you an idea, I am running 175+psi (192 psi at sea level, yes it's been double/triple checked with different testers don't write me...) with +4* timing advance. I was told I probably didn't need to switch, but I did and now I would feel scared to run 8's. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 15, 2007 Report Share Posted March 15, 2007 when is it neceesary to switch to br9es Usually when you make the step up to Methanol Quote Link to comment Share on other sites More sharing options...
Banchetta Posted March 16, 2007 Report Share Posted March 16, 2007 check out my pics and look under plug pics .lookes like thats close to me .ceramic is dirty thanks to my fat fingers almost dropping it and grabing the ceramic end to catch it You pulled the plugs after a wot run in 6th gear for 5-10 seconds, shut the bike off, coast to a stop, pull these plugs out and chopped them??? If not, then you need to....If you did, then your running too rich..doesn't look like a wide open run though. Quote Link to comment Share on other sites More sharing options...
