Poping
Ok guys I just got another banshee on friday and the whole motor was apart. We went throw it and put it all back together on saturday. We fired her up and she was poping on the rightside. We tuned it a bit and it took some out but its still poping when you fire it up. We have done alot of motors before and I have never had this problem. Anybody know whats going on? thanks
-dan
I should add that when it warms up it quits poping. I think it might be that I need to jump up on my main jett size but ?
Without actually riding it, it sounds like a lean condition if you are experiencing this at full throttle situations. Since both cylinders should jet the same, you need to do a plug check from WFO to see if it is indeed lean. If so, you may have a clogged carb, poor porting (if applicable) or an air leak drawing air in and leaning it out. Cracked intake boots can cause this as well. Also a good idea to check your carb balance.
Brandon
I checked the air gap,swaped coil wires, richened it up a bit, checked for air leaks and couldnt find anything wrong. When I swapped the wires it was still in the rightside cylinder.So the coil is fine and the air gap is at .020. We cleaned the hell out of the carbs too but it still doing it. I still think it might be a jett problem or carb problem but I dont know. Anymore suggestions? Thanks
-Dan
-Dan
Since both carbs are jetted the same, and you cleaned the hell out of them...but it only does it on the right side...I doubt highly it's a jet problem unless you didn't clean them good enough.
Time for a leak down test..
I agree. also put brand new plugs in. A few hours old does not cut it. You just need to rule that out. Also check for blue spark and check grounds. Also unhook all the TORS stuff to rule that out as well. A jetting check will help tell the story on this one.
Brandon
