WALLACE84 Posted March 11, 2007 Report Share Posted March 11, 2007 Ok guys I just got another banshee on friday and the whole motor was apart. We went throw it and put it all back together on saturday. We fired her up and she was poping on the rightside. We tuned it a bit and it took some out but its still poping when you fire it up. We have done alot of motors before and I have never had this problem. Anybody know whats going on? thanks -dan Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted March 12, 2007 Author Report Share Posted March 12, 2007 I should add that when it warms up it quits poping. I think it might be that I need to jump up on my main jett size but ? Quote Link to comment Share on other sites More sharing options...
blowit Posted March 12, 2007 Report Share Posted March 12, 2007 I should add that when it warms up it quits poping. I think it might be that I need to jump up on my main jett size but ? Without actually riding it, it sounds like a lean condition if you are experiencing this at full throttle situations. Since both cylinders should jet the same, you need to do a plug check from WFO to see if it is indeed lean. If so, you may have a clogged carb, poor porting (if applicable) or an air leak drawing air in and leaning it out. Cracked intake boots can cause this as well. Also a good idea to check your carb balance. Brandon Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 12, 2007 Report Share Posted March 12, 2007 Yeah, I'd do a leak down test Dan.... Do the simple things, too... Check the air gap on the flywheel/pickup. I'm assuming you're using fresh spark plugs. Swap coil wires, see if it follows the wire. Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted March 13, 2007 Author Report Share Posted March 13, 2007 I checked the air gap,swaped coil wires, richened it up a bit, checked for air leaks and couldnt find anything wrong. When I swapped the wires it was still in the rightside cylinder.So the coil is fine and the air gap is at .020. We cleaned the hell out of the carbs too but it still doing it. I still think it might be a jett problem or carb problem but I dont know. Anymore suggestions? Thanks -Dan Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 13, 2007 Report Share Posted March 13, 2007 I checked the air gap,swaped coil wires, richened it up a bit, checked for air leaks and couldnt find anything wrong. When I swapped the wires it was still in the rightside cylinder.So the coil is fine and the air gap is at .020. We cleaned the hell out of the carbs too but it still doing it. I still think it might be a jett problem or carb problem but I dont know. Anymore suggestions? Thanks -Dan Since both carbs are jetted the same, and you cleaned the hell out of them...but it only does it on the right side...I doubt highly it's a jet problem unless you didn't clean them good enough. Time for a leak down test.. Quote Link to comment Share on other sites More sharing options...
blowit Posted March 13, 2007 Report Share Posted March 13, 2007 Since both carbs are jetted the same, and you cleaned the hell out of them...but it only does it on the right side...I doubt highly it's a jet problem unless you didn't clean them good enough. Time for a leak down test.. I agree. also put brand new plugs in. A few hours old does not cut it. You just need to rule that out. Also check for blue spark and check grounds. Also unhook all the TORS stuff to rule that out as well. A jetting check will help tell the story on this one. Brandon Quote Link to comment Share on other sites More sharing options...
