Help setting up suspension please
jlsparky7
I just installed the hydrodynamics i4500 kit on my shee and I need a little help tuning it. First off I set the camber as close to a 90 degree angle as I could just to start off. I will angle the tires a bit once I get used to the new suspension. I just had a few questions so here they are. (The installation instructions were HORRIBLE!)
What should I set the camber at?
What should I set the preload at?
How do I measure were the preload is set (im going by the # of threads)?
How many clicks should I set the rebound damping at? (22 total clicks I went with 11)
The quad seems to be sitting very high, would more preload lower it?
Have you tried just calling them or emailing them to find your answers?
I figured it would be easier to find answers on here.
If everyone just called the manufacturer for info this site wouldnt be much use :-/
You need to tell us what type of terrain you ride in and what your riding style is like. I will be happy to suggest some settings then. :thumbsup:
