2fast4u2catch Posted March 7, 2007 Report Share Posted March 7, 2007 how do you get the axle out? i took off evrything but it still wont budge> please help thanks justin Quote Link to comment Share on other sites More sharing options...
Hollister_Hitman Posted March 7, 2007 Report Share Posted March 7, 2007 your bearing are shot right? They were making a grinding noise before you took it apart? you are probally goingot to need a big f'in hammer and something put over the hub so that you don;t damage the threads on the axle. Quote Link to comment Share on other sites More sharing options...
2fast4u2catch Posted March 7, 2007 Author Report Share Posted March 7, 2007 no my axles bent and i tried hammering it out it just wont come out Quote Link to comment Share on other sites More sharing options...
sandmouse Posted March 7, 2007 Report Share Posted March 7, 2007 wd-40 the $hit out of it and keep hitting. i had everything off my stock axle and was told if everythings off squirt it and beat it. took me 2 days to get it out. i was pissed. i dont know where the stock axle finally landed. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted March 7, 2007 Report Share Posted March 7, 2007 Good luck! What happens is after so long, the bearings wear out, and all the grease goes away, then they weld themselves to the carrier and the axle. I chucked mine, and bought a new one when I had to do them. The trick on the new one is to tap a grease fitting into the carrier, and grease it once a year. You can try using A LOT of PB Blaster(way better then WD40). Also, if you have access to a hydraulic press that might do the trick. Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted March 7, 2007 Report Share Posted March 7, 2007 I just thread the bolt all the way down on the end of the axle with the hub on, then I put the socket over the nut and knock the shit out of it with a sledge hammer 'till she submits. How bad is it bent? You may have to cut it off. Quote Link to comment Share on other sites More sharing options...
2fast4u2catch Posted March 7, 2007 Author Report Share Posted March 7, 2007 i finally got it out i sprayed some pb on it last night and let it sit and i beat it out today thanks for all of your help Quote Link to comment Share on other sites More sharing options...
