chevrolet banshee Posted March 5, 2007 Report Share Posted March 5, 2007 i wont to get a rev box. but dont know wicth one to get rev max rev box dyna fs ignition electrex cdi unit Quote Link to comment Share on other sites More sharing options...
FireHead Posted March 5, 2007 Report Share Posted March 5, 2007 i wont to get a rev box. but dont know wicth one to get rev max rev box dyna fs ignition electrex cdi unit I reccomend a Dyna unit. I do not have any experience with the other units though. Your max rpm is controlled by your pipes, not the ignition, though. :thumbsup: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 5, 2007 Report Share Posted March 5, 2007 I reccomend a Dyna unit. I do not have any experience with the other units though. Your max rpm is controlled by your pipes, not the ignition, though. :thumbsup: Ditto...dyna makes a nice ignition. To add to firehead's comments.... Your pipes, porting, intakes and carbs control how high and how fast your motor revs. 4 pokes are a different story, because they actually DO have rev limiters built into the ignition.... However.... Is your current CDI bad? What other mods do you have done? Unless your ignition is faulty, I'd say that is one of the last things to get for your bike...stock ignition does the job pretty well... At 250 to 300 bucks for a dyna....other mods will make you go faster. Quote Link to comment Share on other sites More sharing options...
FireHead Posted March 6, 2007 Report Share Posted March 6, 2007 Ditto...dyna makes a nice ignition. To add to firehead's comments....Your pipes, porting, intakes and carbs control how high and how fast your motor revs. 4 pokes are a different story, because they actually DO have rev limiters built into the ignition.... However.... Is your current CDI bad? What other mods do you have done? Unless your ignition is faulty, I'd say that is one of the last things to get for your bike...stock ignition does the job pretty well... At 250 to 300 bucks for a dyna....other mods will make you go faster. ................smarty pants. :biggrin: Quote Link to comment Share on other sites More sharing options...
chevrolet banshee Posted March 10, 2007 Author Report Share Posted March 10, 2007 hey i got k&n filter single carb boison reeds fmf gold seares fmf power core 2 :thumbsup: Quote Link to comment Share on other sites More sharing options...
FireHead Posted March 10, 2007 Report Share Posted March 10, 2007 hey i got k&n filter single carb boison reeds fmf gold seares fmf power core 2 :thumbsup: and.............................. Am I missing something here? Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted May 23, 2007 Report Share Posted May 23, 2007 So what would a max rev box do for me? Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted May 23, 2007 Report Share Posted May 23, 2007 So what would a max rev box do for me? Nothing, unless it advances the timing. And a $35 timing plate will do that. Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted May 23, 2007 Report Share Posted May 23, 2007 So what timing plate do u recommend and is it hard to install it? Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted May 23, 2007 Report Share Posted May 23, 2007 timing plates are simple to install. you can get a pro design, ricky stator and I am sure there are more out there. When you order the adj timing plate order a flywheel puller. you will need it. Quote Link to comment Share on other sites More sharing options...
