10 minutes ago, the boris said:
If you didn't do some extreme mods, like porting, pipes, shaving head, you probably don't have to weld it.
Sent from my VOG-L29 using Tapatalk
65 mm bore
single K&N
no lid
T5’s
as of now
Reeds and Timing advance in the near future
  • Like 1
So... dude I bought the bike from failed to mention that he put a timing plate in when I asked for ALL of the mods he did.
so now I have this one that I don’t need. Unless it fits a blaster too? Wishful thinking probly
Looks quite different from the one on blaster, just sell it.
On 1/20/2020 at 5:23 AM, Deets said:
It is a cast one on there now. Junk?
Usually. Some times the bolt hole eyelets crack and then let the plate loose. Then it bounces off the stator and flywheel. It can get pricey real quick.
15 hours ago, Deets said:
Thanks, I’ll get it swapped out.
There is a line in the casting, I’m assuming that is where you orientate the timing from.
The line where the case halves meet is what you dial the plate to. +4 is pretty widely used on pump gas motors with out a ton of compression. You have a real flywheel puller, right?
Yup, I figured that was the line.
yeah I bought one off eBay
  • 10 months later...
Is someone know the bolt size for the pick up coil because I will need 2! When I try to unscrew the pickup coil from the oem plate I stripped the bolt and need to know the size and thread and length of the bolt?
