Yes. I liked all my shee at +4. Noticeable difference.
Did you have to increase your idle speed when you installed the plate?
I use to run mine at 980-1000 rpm but now with timing plate installed I have to keep it @ at least 1150 but at 1200-1250 runs the best.
Sent from my ONEPLUS A3000 using Tapatalk
  • 3 months later...
5 minutes ago, the boris said:
There were even offset keys to buy few years back, not sure if you can get them now.
Sent from my VOG-L29 using Tapatalk
Only takes a minute to file one, I do it in saws all the time
Edited by Deets
  • Like 1
Just be wary with doing it on the quad bike because it's not a chainsaw. With that said, on quad bike acceleration and deceleration is much more extreme than on the chainsaw.
I will disagree about the acceleration part, most of my saws run 14,000 - 16,000 rpm
  • Like 1
Hard acceleration and deceleration with down shifting can even walk the crank open over time,so there is a chance to cut the key too.
Ah, didn’t think about downshifting. I see what your saying.
I’ll lap the taper fit
  • Like 1
I’ve sent small stuff to Falicon before, but heard they quit doing it. Maybe they still do multi-cylinder cranks?
I can tig weld but fear drawing it out of true.
If you didn't do some extreme mods, like porting, pipes, shaving head, you probably don't have to weld it.
