What ever you do, DO NOT USE WISECO PISTON RINGS WITH STOCK BANSHEE PISTONS!!! The lower piston ring is a different size then the upper ring on a stock piston. The Wisecos are both the same size, which creates too much free-play in the lower ring and this is what happens!!!
Check out the pics of my cylinders! http://s106.photobucket.com/albums/m261/ltzryder21/
The Wiseco rings are for a forged piston and the stock pistons are cast. Hence the difference and the unfortunate result listed above. :thumbsup:
