Anyone have a pic of where TDC is on my case?? Also, if I am advancing timing to +4, which way do I rotate te plate? Thanks in advance..... I think Blue Traxx used to have this on their site but I cant seem to find it now..
The line where the upper and lower cases meet is what you use to set the timing plate. You turn it clockwise to advance. Every aftermarket timing plate I have seen has the degrees marked off on it so it's easy to set at +4 or what ever you want. If you're trying to modify a stock plate you will probalbly only be able to get about 2 degrees out of it.
