Pipe Hangers
baddsheee
Got my Shearers in. I seen that my stock exhaust pipe hangers look like they are falling apart in the rubber. Do I need some kind of flexing in them. I am making them out of 1/8" stainless steel plates, very sturdy. I am going to do the offsets for the shearers if they don't line up, so I don't end up with a stack of washers.. I seen the aftermarket hangers and they look like they don't have any rubber built into them. Do you guys think I'll be OK with stainless steel.
Not sure if its the best way to do it but.. I picked up some thick rubber washer type things from the local hardware store.. Just something to take out some vibration so its not so hard on things.. As far as if you REALLY need something like that, Iam not sure..
RIPPEN
RIPPEN
I was thinking of a nylon washer between the pipes.
I think you do, but a lot of guys run those aftermarket hangers that look to be solid stainless or steel with chrome. I see how much my pipes vibrate when I'm riding, and I wouldn't want all of that trasferred to the frame. It seems like you would fatgiue that part of the frame, or at least the bolt, after a while. Just my .02, I'd use something, even a washer would help.
I was told that you want those things to be pretty much solid. The rubber in the stock hangers may absorb the vibration at the mounting point at the frame, but then you end up with most of the vibration going to the next point of least resistance - your exhaust ports - BAD.
IDK - that
Buy some stock new ones, drill two small holes in each and put a screw and nut in. Compress the rubber just so sligthly when you tighten the screw and add a little locktight to the nut. Probelm solved.
Chris
if you dont mind the hangers looking like crap... id rather spend some extra money and have someone else do it right and make it look good at the same time casue i know my self and many others can say oh yea i can do this myself and it ends up being shity casue we dont have the right tools or experiance or time or what every the case may be....
Understandable, but don't assume that if someone does it this way that it looks like crap. All you need is a small size 8 screw, and paint the hangar and it will be very hard to tell. Of course I also run full frt plastic so you will never see the screws anyway.
Chris
IDK - that
They look good to me :shrug: and weren't expensive either, less than the price of the few stock hangers that you keep on reserve.
I'm not worried about the hanger brackets on the pipes braking, or the welds, they are very strong. But I also have Stainless Steel pipes which are a thicker gauge and more resilient than pipes made from mild steel with chrome plating.
They may not be for others, but they work great for me. Like I said they made my pipes fit a lot better than they did with a set of brand new stock hangers. Better offset I think.
Personally, if your motor vibrates so much that it brakes welds and/or shears bolts, you have bigger problems than pipe hangers.
:beer:
Edited by AssWhore
Choped out the thin metal gus on frame-welded in a tapered frame clip from a stock car-shaved a rubber boxs mount from a pickup-and got cascade hangers. solid as can be but tons of flex for no stress on anything. worth the time and effort. :thumbsup:
