greg_banshee Posted February 20, 2007 Report Share Posted February 20, 2007 what do you guys think about this set up ? i'm looking for something like this but would love a 4 mil stroker but might settle for this if necessary. what are your thoughts let me know ! http://cgi.ebay.com/ebaymotors/LA-Sleeve-B...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 20, 2007 Report Share Posted February 20, 2007 i wouldnt bother with that. you dont need a huge bore to make a lot of power... Quote Link to comment Share on other sites More sharing options...
greg_banshee Posted February 20, 2007 Author Report Share Posted February 20, 2007 was also looking into the 4mil Cub i pretty much only do wide open old loggin roads/dirt roads/open gravel pits ? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 20, 2007 Report Share Posted February 20, 2007 A cub would be 10X the motor. You can get the 64mm standard bore cub, 68mm big bore cub, or the 72mm super cub. If you want to do a stroker then make sure you waite to get the right cylinders. I wouldnt buy a stock stroke cub and then a month later try putting a stroker crank in it. josh Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted February 20, 2007 Report Share Posted February 20, 2007 But remember when you go with the cub you will need Pipes,Carbs,Lockout clutch,Overide(RECOMENDED),Swinger,Tires ETC. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 20, 2007 Report Share Posted February 20, 2007 i really think you can just get by with some good porting, pipes, carbs, intakes, advance timing and so on... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 20, 2007 Report Share Posted February 20, 2007 But remember when you go with the cub you will need Pipes,Carbs,Lockout clutch,Overide(RECOMENDED),Swinger,Tires ETC. Pretty much the same thing he should have if he got the 409 kit as well. Then he would still be getting beat by faster cubs. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 20, 2007 Report Share Posted February 20, 2007 You will not make as much power as a cub with this setup. With extensive porting, I've seen an LA Sleeve motor run well. I think for about half of that, you could get a good strong dune port for your motor that will make you happy. Also, are you prepared for bigger carbs, mid to top end pipes, longer swinger, chain, gearing, tires, etc?? Quote Link to comment Share on other sites More sharing options...
