paulnyw Posted February 17, 2007 Report Share Posted February 17, 2007 ok i want to install a adjustable timing plate my question is what else do ihave to do when i advance the timing? rejet? and is any other parts needed besides the timing plate? thanks Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 17, 2007 Report Share Posted February 17, 2007 ok i want to install a adjustable timing plate my question is what else do ihave to do when i advance the timing? rejet? and is any other parts needed besides the timing plate? thanks A timing plate is pretty much all you need. You will need to do a plug chop to make sure the jetting is ok. Sometimes you have to rejet, sometimes you just have to fiddle with the air screw and needle position. :thumbsup: Quote Link to comment Share on other sites More sharing options...
moneybags Posted February 17, 2007 Report Share Posted February 17, 2007 Your going to need a flywill puller to get if off. Dont use a 3 jaw puller. If you dont have a impact gun your going to need something to hold the flywill, When you go to tighten the bult down. Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 17, 2007 Report Share Posted February 17, 2007 Your going to need a flywill puller to get if off. Dont use a 3 jaw puller. If you dont have a impact gun your going to need something to hold the flywill, When you go to tighten the bult down. Good call. I forgot all about needing the puller. I'm retarded. :shoothead: Quote Link to comment Share on other sites More sharing options...
Dinner Posted February 17, 2007 Report Share Posted February 17, 2007 Curious...why not use a 3-Jaw puller? :shrug: Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 17, 2007 Report Share Posted February 17, 2007 It can and usually does distort/ruin the flywheel! Quote Link to comment Share on other sites More sharing options...
04banshee_fmf Posted February 17, 2007 Report Share Posted February 17, 2007 A timing plate is pretty much all you need. You will need to do a plug chop to make sure the jetting is ok. Sometimes you have to rejet, sometimes you just have to fiddle with the air screw and needle position. :thumbsup: hey im pretty new to this to.... probably a dumb question but what do you mean do a plug chop? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 17, 2007 Report Share Posted February 17, 2007 hey im pretty new to this to.... probably a dumb question but what do you mean do a plug chop? http://www.dfn.com/benkaren/plugchop.html http://www.dfn.com/benkaren/jetfaq.html Quote Link to comment Share on other sites More sharing options...
LeadBoots Posted February 17, 2007 Report Share Posted February 17, 2007 Your going to need a flywill puller to get if off. Dont use a 3 jaw puller. If you dont have a impact gun your going to need something to hold the flywill, When you go to tighten the bult down. can u use an impact to put the flywheel bolt back on? Quote Link to comment Share on other sites More sharing options...
rideblue_05 Posted February 17, 2007 Report Share Posted February 17, 2007 can u use an impact to put the flywheel bolt back on? I just put an adjustable plate on mine the other day. I used an impact to put the nut back on. Works good if you dont have a strap wrench or something else to hold the flywheel. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted February 17, 2007 Report Share Posted February 17, 2007 can u use an impact to put the flywheel bolt back on? You shouldnt. you can overtighten it, and then youll need a new crank. Buy a flywheel holder, from your local cycle shop, or make one. Put 2 bolts through a 2x4, at the same spacing as the holes on the flywheel, and use a spade bit to bore a whole at the location of the nut, you can then hold the flywheel while you tighten or remove the nut. You can use a strap wrench too, but I never had a lot of luck with them. Quote Link to comment Share on other sites More sharing options...
