May Posted February 15, 2007 Report Share Posted February 15, 2007 i lost the seal on the bottom of the jug that goes into the water main where can i find another thanks Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 15, 2007 Report Share Posted February 15, 2007 That's a good question. I would be interested in the answer. Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted February 15, 2007 Report Share Posted February 15, 2007 if you can post up a pic of it i will look and see if i have one. i have a bunch of little parts that i don't know what the are. so if you post a pic i can look for one for you. Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 15, 2007 Report Share Posted February 15, 2007 Its going to be a kidney shaped rubber piece. I am interested in what you are supposed to if you lose these things, since Yamaha doesn't sell them separately. Several years ago I lost one of the plugs, but I never found a replacement or any other alterantive, so I had to weld the coolant jacket shut inorder to use the cylinders. Needless to say, I do not reccomend doing this, and I didn't run the cylinders for very long. I wound up scrapping them and using part of them to prove out some tool paths on. :thumbsup: Quote Link to comment Share on other sites More sharing options...
May Posted February 15, 2007 Author Report Share Posted February 15, 2007 wonder what would happen if i ran them without that peice i guess water would leak and as far as a pic i will get one later today Thanks Andrew Quote Link to comment Share on other sites More sharing options...
Hilarious Posted February 15, 2007 Report Share Posted February 15, 2007 You fellers are talking about the little rubber plugs right? #6 www.bikebandit.com Quote Link to comment Share on other sites More sharing options...
seabass Posted February 15, 2007 Report Share Posted February 15, 2007 (edited) If it is #6, I just received two of them through my local yamaha dealership. :thumbsup: Edited February 15, 2007 by seabass Quote Link to comment Share on other sites More sharing options...
87_shee Posted February 15, 2007 Report Share Posted February 15, 2007 Yes you can buy these, I just got 2 of them from my local stealership, only cost $4.44, and if you dont have them they WILL leak coolent. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 15, 2007 Report Share Posted February 15, 2007 If your local dealer doesnt have them we stock all that kind of OEM parts!! :thumbsup: Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 15, 2007 Report Share Posted February 15, 2007 If it is #6, I just received two of them through my local yamaha dealership. :thumbsup: Dammit. When I was looking for those things a few years ago tow Yamaha dealers told me that I had to buy new cylinders since you couldn't get those parts. Of course that's all before I joined the forum and probably didn't know any better. I did try running without the plugs as well as fashioning my own plugs out of a few different materials. In both cases I wound leaking water, both inside and outside the engine. I suppose the moral of my story is that I learn something new every day. :thumbsup: Quote Link to comment Share on other sites More sharing options...
headsup Posted February 15, 2007 Report Share Posted February 15, 2007 i lost the seal on the bottom of the jug that goes into the water main where can i find another thanks the way to magnatize a custom piece of metal is simply to wrap as many coils of insulated wire as you can around it tightly, then momentarly ground out to each battery termal, i maybe 2 times. just spark it. that piece of metal will now be magnatized. Quote Link to comment Share on other sites More sharing options...
letsgetthisdone Posted February 16, 2007 Report Share Posted February 16, 2007 the way to magnatize a custom piece of metal is simply to wrap as many coils of insulated wire as you can around it tightly, then momentarly ground out to each battery termal, i maybe 2 times. just spark it. that piece of metal will now be magnatized. WTF? slightliy off-topic bro. :beer: Quote Link to comment Share on other sites More sharing options...
headsup Posted February 16, 2007 Report Share Posted February 16, 2007 WTF? slightliy off-topic bro. :beer: right, thought i was responding to the question about the broken off drill bit, i should have read more throughly. Quote Link to comment Share on other sites More sharing options...
May Posted February 16, 2007 Author Report Share Posted February 16, 2007 Man thanks for all the info im going to order some friday Thanhs again Andrew Quote Link to comment Share on other sites More sharing options...
