bertski077 Posted February 15, 2007 Report Share Posted February 15, 2007 will the one inch that the yfz shocks make your bike sit higher effect the way the bike handles on a mx track??? Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted February 21, 2007 Report Share Posted February 21, 2007 will the one inch that the yfz shocks make your bike sit higher effect the way the bike handles on a mx track??? i have a set and it sits higher but i never have a problem with it affecting the way it handels. i have more good things to say about them then bad things. Derick Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted February 21, 2007 Report Share Posted February 21, 2007 Don't spend too much on them if you go that route. If you can find some truely that are cheap they would be worth it (100 dollar range and under). Anything over 200-300 just isn't worth it at all. You can get some basic dual rate works valved for your application that'll outperform the yfz shocks 10 to 1 for maybe 1-2 hundred more and it won't effect your ride hieght (which no matter what someone may say will effect the center of gravity making it slightly more unstable in the corners, granted it's not much but it is noticable and every little bit counts). Quote Link to comment Share on other sites More sharing options...
