cleaning crank case
how should i clean it. their alot of dirt inside of it.
its for a blaster by the way
I'd say maybe carb cleaner or Brake cleaner it evaporates pretty quick... but you have all the guts out of it take a pressure washer to it but thats only if you have all bearings and any other internals out
i wouldnt use brake cleen. it will eat at the cases. use carb cleaner instead, its made for ferous metals. or best is take it to the car wash and pressure wash it. then once it dries out, spray it down with wd40.
dont want to start a beef, but brake cleen wont hurt the cases.. if it would hurt them mine would be fully disolved by now. That shit will hurt you alot more then the cases.
kindof what i was thinking, isnt brake cleaner and carb cleaner basically the same thing, just ina different can?
No...
Carb cleaner I've used leaves a little bit of an oily film behind, whereas brake cleaner dries quickly and clean.
I agree...I've always used brake cleaner with great results....shit will burn your hands with too much exposure, though...
Powerwash then brake clean it...then power wash again!!
i think brake cleen is a different chemical than carb cleaner. carb cleaner definetely isnt as strong. also, some brake cleaners have chlorine in it. so im sure that would affect the cases if it was left on.
