What Race Fuel
BlackBarron
right now i am running 19cc domes and the only gas i can get localy is 110 octane. i know with 19cc domes you have to have 105 octane, but will 110 octane work??? thanks alot
have you checked your compression? on a stock bore at the right elevation you might be border line super at the pump or a 50/50 mix of 105 and 91/93............ all you can get where you live is 110? any gas station has super unleaded i think unless you have upwards of 150 psi in your jugs your on super, pump fuel
Edited by Blue Duece
ok, let me rephase the question. i know i need at lease 105 octane gas, my Compression 180psi, because i have 19cc domes.so i know i need race fuel, but what i need to know is can you have to much octane.
Let me guess. You know you have 180 psi because the chart says so. :shoothead:
I run 19cc domes and have 150 psi on each side.
Try doing a compression test and then re ask the question.
You know what happens when you ASS U ME
Very good point Jbooker.
Never assume. Get a good quality tester, a complete tester kit from Craftsman runs 60 bucks.
Check it...
Report back what you find, but...all I have around here is 110 octane too.
If you're at or near 180 PSI or so, yeah, 110 is a good idea.
I ran 110 in my 185PSI cub motor with a lot of timing, no issues.
