Warped head and cylinder?
87_shee
Hey guys.. Well I got my cylinders back and have been having some trouble getting everything to seal right. I had bought some cheap ass gaskets on ebay and I guess you get what you pay for, because they were junk every single one leaked, causing the motor to hydrolock after about 2 seconds. Also the rubber plugs were all F***ed up so I got some new ones along with some new yamaha gaskets and I cleaned all of the mating surfaces and put everything back together, torqed everything in increments to the specs in my clymers, started it up and its still leaking. When I started It, It was blowing out the Radiator overflow hose so i know its my head gasket not sealing right..but its also dripping a little bit from the base of the cylinders. So my question is could my head and cylinders be warped? If so what can I do about it? Does resurfacing with sand paper like it says in the clymer work? I seized a bearing on the crank in august but would that have caused things to warp? Sorry for the long post... i just want to get this thing fixed :banghead:
Honestly, If you have never done this type of stuff before take it to your builder and have them blanchard grind it or mill it flat. Piece of mind. While you are at it take your bottom end in and have him check the base for flat as well.
