DuNeKilla1 Posted February 12, 2007 Report Share Posted February 12, 2007 I need to know if there is a way to tell the difference between a HotRods 4mmstroke 5mm longrod,and just the longrod crank,and what if any case mods need to be done in order to run the one of the two?Thanks Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 12, 2007 Report Share Posted February 12, 2007 No case mods to run ethire. I am not for sure how you tell the difference between a long rod stock stroke and the long rod 4mill stroke. Quote Link to comment Share on other sites More sharing options...
lowriderb Posted February 12, 2007 Report Share Posted February 12, 2007 with stock jugs and no spacer plate the 4mm should have the pistons coming to a positive deck height.. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 12, 2007 Report Share Posted February 12, 2007 No case mods at all, drop in crank at 4mil. Larger than that, the cases have to be trenched. A longer rod will require different pistons, 795 or stroker series pistons. A longer STROKE will require a spacer plate or the head/domes to be cut since the pistons will be run up into the head... AND....porting and port timings should be matched for the longer stroke, as well.... Quote Link to comment Share on other sites More sharing options...
Crazy05 Posted February 23, 2007 Report Share Posted February 23, 2007 I need to know if there is a way to tell the difference between a HotRods 4mmstroke 5mm longrod,and just the longrod crank,and what if any case mods need to be done in order to run the one of the two?ThanksIf its just a 4mill the rods will be stock length. If its a longrod 4 mill. The rods will be longer than stock. Long rods are better as I'm sure you know but they require a special piston that has the wrist pin higher in the piston to make up for it. Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 23, 2007 Report Share Posted February 23, 2007 You don't necesarily need the 795 pistons to run a stroker or long rod setup or even both at the same time. The long rods should measure 120mm center to center as opposed to 115mm (I may have that messed where as it is 115mm compare to stock at 110mm). As for crank stroke, unless you have a way to measure the crank between centers, you had better hope that the crank has markings onit that indicate what it is, otherwise it may be tough to do. :thumbsup: Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted February 24, 2007 Report Share Posted February 24, 2007 Stock rods are 110mm, and the long rods are 115mm. Quote Link to comment Share on other sites More sharing options...
